Old 03-24-2010, 05:55 PM   #1
fr8tshaker's Avatar
2006 34' Classic
Sioux Falls , South Dakota
Torched And Freezing
My conventional oven developed the same problem of a cracked line with propane leaking as several others have while I was home in December. I did not have time to return to AOA for a repair before returning to work.
My only option was to turn off the propane and use a space heater and my electric hotplate..
It created a situation I had not considered.
I returned to AOA yesterday. The repair was make and the crew installed a manual shutoff under the stove top. This will enable me to cut off the propane to the stove only and continue to run the furnace should such a situation occur in the future.
Of course the fridge has a manual cutoff for the propane if it should develop a leak enabling me to take the same steps to maintain the furnace operation.
Nothing lost, nothing gained.
FWIW
'shaker
2006 34' Classic LTD
2010 Ford F250 PSD
Hensley Arrow Hitch
fr8tshaker is offline   Reply With Quote
Old 03-24-2010, 07:21 PM   #2
_
good report shaker...
so the guys at aoa are still doing good deeds and reliable fixes...
for those NOT aware of the gas line issue,
here is ONE of the threads on this topic with good info and excellent pictures...
http://www.airforums.com/forums/f426...lem-43801.html
this issue is SO IMPORTANT and so specific that it should be a sticky somewhere...
and with a real vehicle assembly plant this would be a RECALL
and there would be a STANDARD fix made available...
cheers
2air'
Just a few nights of freezing? ovrteakettle Winter Living 22 12-15-2009 01:50 PM
freezing problems sherryht2 Plumbing - Systems & Fixtures 7 10-31-2009 03:28 PM
Below Freezing While Driving Bluto Full-Timing, Winter Living & Workamping 16 10-26-2009 07:31 AM
Freezing in CT.... NOT! bobfowler All Argosy Trailers 14 12-03-2008 07:44 PM
Freezing RV Antifreeze Raptorrider2001 Winterizing, Storage, Carports & Covers 1 01-13-2003 01:33 PM
