Hi Folks my question is this winter I want to kind of respectfully "gut" my '66 Overlander to replace her floor and do some major work in the galley area. So several questions: to the right of where the oven used to be, inside the cupboard where the "towel rack" is there is a plastic looking tubing or vent that is quite large that goes throught the back of the cupboard on the right and up...was that a vent for the oven? Can I remove it to gain more space without sacrificing something I am not aware of?
Next question, facing the sink, on the right is where the doorway leads to the back of thr trailer. On the otherside, to the right of the room divider next to the sink is a PVC 3" black pipe that appears to start under the floor and go through th overhead storage and out to the ceiling. What is this? Can I reroute it more towards the side?
Lastly (who am I kidding) if I am going to go to the effort to replace flooring and cabinetry should I replace the piping for the water or gas as I am exposing them now. So far, I have no leaks but notice that the gas is copper (I assume that is good?), but the water, at least at the kitchen sink area for drainage is the rigid 3" plastic piping that runs under the sink through the devider wall, along into the bottom of th closet and then down and out.
About the copper piping..I am referring to a 1/2 inch copper line that starts somewhere in front, under the front sofabed and follows along on top of the floor and tight next to the wall on the street side of the trailer, goes under the table, behind the fridge and oven space.
Also, in the front cabinet over the sofabed, there is the two door opening up...in th right upper corner I have a serious looking wire that has been cut. What is this, 12 volt? 110? Something else?
Looking forward to knowing....
