Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Prev Previous Post   Next Post Next
Old 07-17-2006, 08:21 PM   #1
RobertC's Avatar
Profile:  1970 21' Globetrotter
Pickens , South Carolina
Testing the Stove Power Vent
Hello everyone,
I started testing some of the other power things last night. I tried the stove power vent but nothing. So I checked the switch wires first, yep found a loose wire from the Stakon terminal. I thought I would just "spark" the two wires together just to see if any power was there, yep got a spark. So I held the two wires together to see if the motor would run, nope a bad hum. I then went to the outside and removed the vent cover, it looked like a piece of gray paper was covering the round hole! I scratched away at it with a screw driver and found the screen and motor mount. After the screws were removed I tried to pull the motor out, Hmmm, kinda stuck! I pulled it out as gently as I could. This is what I found in there
RobertC is offline   Reply With Quote
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 07:03 PM
2003 International AS Pahaska 2003 International 147 05-28-2004 10:48 AM
power boosters John Our Community 18 11-19-2002 04:54 PM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 01:59 PM
Power lift vent with fan. fphil Roof Vents, Skylights & Fans 4 10-05-2002 08:44 PM
