Old 11-20-2010, 07:17 AM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Stovetop Removal and Cleaning
Is there a way to remove the bifold stovetop on a Magic Chef stove/oven without dismantling the top of the stove. It looks like it should just lift off. This stove is our of our "78" Ambassador. Also, what have others used to clean the top...will eventually have it powder coated. Thanks much!
TAC PA-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
Old 12-19-2010, 12:27 PM   #2
1975 31' Sovereign
1981 31' Excella II
longview , Texas
I have a '75 model with a Magic Chef. I removed the cover fairly easily. Take a flashlight and look down at the rear corner brackets, where it pivots. You will see a slot in the bracket where the pivot pin slides fore and aft. The bottom of this slot cut out so the bracket can be "lifted off the pivot pin". Lifted means you might have to put a screw driver under the bracket and pry it off the pin, especially if the bracket is somewhat bent which closes up the gap where the pin slips out. I actually took a pair of pliers and bent the bracket to open up the slot a little before I reinstalled the cover.
Name:	stove bracket.jpg
AirDD is offline   Reply With Quote
Old 12-19-2010, 12:29 PM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Mine is stainless steel. It had quite a lot of surface rust. We used fine steel wool, and then good metal polish. It looks 110 times better now.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 12-19-2010, 02:40 PM   #4
A 7th year newby
IndyAnne's Avatar
1968 24' Tradewind
Indianapolis , Indiana
Images: 8
Send a message via Yahoo to IndyAnne
Magic Chef folding cover
The slots cut in the bottom must have come along after 1968. I had the problem of screws being stripped out and was unable to get the lid off until I removed the whole range from the cabinet. I was going to do that anyway, so I guess I was not as creative as I could have been. I will certainly cut the grooves before I reinstall this week!
Thanks for the photo and sharing the experience of polishing.
Anne
Anne
Indianapolis, IN
TAC IN-7
1968 Airstream Trade Wind
2005 Chevy K1500 crew, reg. bed, 4WD, gas
IndyAnne is offline   Reply With Quote
Old 12-19-2010, 03:10 PM   #5
Lothlorian's Avatar
Loganville , Georgia
Mine has slots also. It comes out and you will not have to take the stove apart. Mine was steel with rust. I recommend having it poweder coated. It will always look great.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
enlighten me.....stovetop THEPILL 2006 - 2010 International 17 04-09-2010 04:48 PM
Replace stovetop with stove/oven combo - 73 Sovereign Dieselgrin Stoves, Ovens & Microwaves 6 09-30-2009 04:20 AM
Water level Sensor removal/cleaning/replacement outofcontrol Fresh Water Systems 2 02-14-2008 02:39 PM
where can i find a new stovetop roadtrip07 Stoves, Ovens & Microwaves 1 07-13-2005 02:11 PM
Stovetop & Hubcap lmbando 1974 - 1979 Sovereign 5 08-16-2004 09:39 PM
