10-03-2011, 11:47 PM
Salem
, Oregon
Stove top grommets.
Hi, my trailer has the Amana stove with eight rubber grommets holding the grates. Is there a better grommet or have you just replaced them with the same thing? Mine seem to be ready for replacement. I searched the automotive and hardware stores and couldn't find anything with a 1/2" OD and a 3/16" ID. I have read where some people glued a flat washer on the tops of their grommets. I also read where a few people have used the bottoms of tire valve stems. Although the grommets look like rubber, they are silicone, according to what I have read. Tell me/us what you have done for your stove top grommets.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
10-04-2011, 04:36 AM
1981 27' Excella II
mays landing
, South Jersey
We never had this problem, but maybe the right size gas line cut to length? Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
10-04-2011, 04:53 AM
2005 30' Classic
Burlington
, Ontario
Not familiar with the grommets though I suppose ours must be the same - my first thought would be to contact Amana - quite possibly they'd stick a few in the mail no charge.
One thing that concerns me about our cooktop is the folding corian cover. A couple of times it has fallen down from its upright position. Fortunately never when there was a pot of water boiling on top of the range, but that could be nasty.
You have reminded me that I wanted to devise some sort of security clip so that this could never happen. Time to add a note to my "Airstream to do" list !
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
10-04-2011, 05:50 AM
Retired.
, At Large
I've had dozens of Airstreams come through the shop with those grommets missing or broken. They're easy to change, and fairly cheap, but it's still a PITA to have to change them.
10-04-2011, 05:52 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Bob,
In my junk drawer....I know you can relate to this, we all have them. Funny how we kept all that small stuff that we just couldn't toss.
Our grommets also shredded after a few years. Surprisingly I found four,(all I needed at the time), in my tool box. A small dab of Permatex W/strip in the groove on install. When I went to re-install the grates I noticed how asymmetrical they were, the pegs weren't even close to aligning up with the grommets. I carefully bent each foot,(wrap with rag so you don't chip the powdercoat), small dot of white paint on the bottom of the top left foot so they go back in the way they came out. With no stress on the grommet groove they have lasted well.
12-07-2011, 02:23 PM
Wise Elder
2010 30' Classic
South of the river
Photos of my mod are here:
http://www.airforums.com/forums/f426...nge-68533.html
12-07-2011, 02:34 PM
2003 22' International CCD
Kiln
, Mississippi
I took the remains of one to the local electrical supply store. They had rubber - not silicone - wire grommits that did the trick. They were cheap enough that I bought 10 - I believe they were .29 or .49 cents each. Some dish soap and they slipped right in. I don't have the part number - I brought the top half of the original for a size match. Little tight but I only remove the top once a trip - after I get home - for cleaning.
Michael & Tina with Layla and Preston BZ The family has grown. 2003 22' INTERNATIONAL CCD
12-07-2011, 05:32 PM
2006 19' Safari SE
Tucson
If you have a super-Ace Hardware near you take one in and see if they can find something to match or come close to. We have a super-Ace and I am continually amazed as all the little esoteric things like that they carry. Even a regular Ace have a huge inventory of waters, grommets, screws, bolts, washers, etc etc...I am always impressed. Home Depot or the likes probably have them, too, but nobody ever seems to know where anything is. (Talk about the blind leading the blind.)
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
12-07-2011, 05:53 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Grommets
I lost one somehow. Went to a local RV store and they sold me a new set of four for $1.69.
Paula
12-08-2011, 12:09 PM
2005 28' Safari
Mono City
Bob,
Have you tried McMasterCarr?
McMaster-Carr
They have a warehouse in LA County, Santa Fe Springs
Good luck!
12-08-2011, 03:37 PM
1960 28' Ambassador
1998 25' Safari
Avonton
, Ontario
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
01-26-2012, 08:31 PM
Salem
, Oregon
Stove top grommets.
Hi, today was a great day to play with my Safari. After searching for stove top grommets for my Amana, I found out that they are universal from Camco. I bought two packs of four. The old worn out grommets came out very easily. The new ones popped right in. I decided to super glue 3/16" flat body washers on top of them. I don't cook with heavy cast iron pots, but I think they need a little help. Mine were the original, seven year old grommets. Cost me about $10.00 for the grommets, washers, and super glue. Will these last for another seven years?
09-17-2012, 07:20 PM
2010 23' International
Saturna
, British Columbia
I'm about ready to toss my whole stove out and replace it because of those rinky dink grommets holding the grill. In my 2010 International 23, the grill always sinks down on to the gromments as soon as my wife cooks on it until the grill lies on the actual burners.Net result is the grill paint is burned off on spots and now rusting or corroding. Replacing the grommets solved nothing.I'll try the glued on washer idea and see what happens.
If you hear a big "Crash" you'll know it didnt work!! Should that happen can any one offer an opinion on a replacement stove/over?
"I carry what I can, and leave the rest behind" Epicurus
"All that is mine, I carry with me." Cicero
