Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 07-19-2004, 10:37 PM   #1
TroutStream's Avatar
Profile:
Stove Rings - Re-enameled??
Has anyone re-enameled the black cast iron rings on their stove? Ours look good except for the centers where the enamel is worn, so I was thinking about re-enameling or painting with some kind of hi-heat, hi viscosity enamel paint.
Any suggestions?
Ken
TroutStream is offline   Reply With Quote
Old 07-19-2004, 11:14 PM   #2
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Good question...I've wondered the same.
We've found antiquegasstoves.com which does beautiful restorations on home stoves & it says they restore grates too...but I haven't gone any further (pricing?) at this point....just have them on 'our list' for future reference.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
InsideOut is online now   Reply With Quote
Old 07-19-2004, 11:45 PM   #3
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
My suggestion would be powder-coating. They powder-coat headers so I know it can take the heat. If I remember right, its alot less expensive than getting things chromed. There are a number of different colors available as well. That's on my list of things to do as too - someday.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 07-20-2004, 01:35 AM   #4
Profile:
FF,
Thanks, I'm going to check into powder coating. I hadn't even noticed the stove rings and if I had, they would have been far down on my list. Of course they're near the top of my wifes. This is a good sign though it means we're getting some of the major stuff done, had the wood laminate floors installed and am picking up the newly upholstered beds and gaucho tommorrow.
Now... to get that toilet back in...
Old 07-20-2004, 05:54 AM   #5
Master Riveter
Sneakinup's Avatar
Profile:  1972 27' Overlander
. , Mobile-- as in transient
Images: 72
Send a message via AIM to Sneakinup
I had mine powder coated with the high heat paint. Came out looking brand new. I haven't really used the stove top much since, other than letting it burn for a while during testing of the propane lines and such, but it seems to be holding up quite well.
Definitely go with powdercoating.
1972 27' Overlander 72 Overlander
Jack Pad--- A notebook used by Jack Nicholson in the Shining to keep track of how much work he had done on his Airstream. "All work and no polishing makes Jack's Airstream a dull trailer"
Sneakinup is offline   Reply With Quote
Old 07-20-2004, 08:56 AM   #6
fireflyinva's Avatar
Profile:  1961 22' Safari
Vienna , Virginia
Is powder coating something you can DIY? If so, what paint do you use (I've seen high heat paint for grills and radiators--will it do)? If not, what kind of shop does it? What should I look for in the phone book? How much did it cost?
Mary
fireflyinva is offline   Reply With Quote
Old 07-20-2004, 09:04 AM   #7
Master Riveter
Sneakinup's Avatar
Images: 72
Mary
You can do it yourself, but you need to buy a powdercoating kit for around $75, and have an oven to bake the painted parts in, as well as purchasing powder. Unless you plan on doing a lot of painting, have someone else do it.
The best bet is to just look in the YP's for Powder Coaters, and if you are in a fairly good size town/city you should find dozens of them.
Old 07-20-2004, 09:36 AM   #8
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
Is powder coating something you can DIY? If so, what paint do you use (I've seen high heat paint for grills and radiators--will it do)? ....
Caswell's advertises as a "Hobbyist" coating retailer. Just had the Bookmark if I ever have the need. Never used them before.
http://www.caswellplating.com/powder/index.html
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 07-20-2004, 09:42 AM   #9
Profile:  , Minnesota
Images: 59
You might try POR-20 (silver) or Black Velvet http://www.por15.com/product.asp?productid=268, good to 1200°F
markdoane is online now   Reply With Quote
Old 07-20-2004, 10:11 AM   #10
Profile:
Just talked to a powder coater who said it would cost about $50 to do all four burner rings but he did say that it is not really intended to be subjected to flames (more like heat up 300 degrees). He says that in time the flames will burn the coating off.
I may still try it.
Ken.
Old 07-21-2004, 02:37 PM   #11
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Powder Coating
I may still try it.
Ken.
I had mine powder coated and it melted off onto the bottom of my pans!!
Not a good idea.
Don
Gunnyusmc is offline   Reply With Quote
Old 07-21-2004, 02:50 PM   #12
Master Riveter
Sneakinup's Avatar
Images: 72
I have left all 4 burners blazing for at least a half hour while testing out my propane lines, and all the powder was still in tact. I didn't have a pot or anything sitting on it at the time. The company that did mine assured me that it would easily take the heat. We'll see how it goes in real world situations soon enough!
Old 07-21-2004, 03:03 PM   #13
Jabba's Avatar
Profile:  1955 30' Sovereign of the Road
, Michigan
I got pricing last spring on having our rings re-enameled, if I remember correctly it was going to be in the $125-$150 range. Needless to say they look great for now
Jason & Veronica Jablonski
S.E. Michigan
1955 Commodore Vanderbilt/Liner 30'
2008 Chevy Silverado Ext. Z71 w3.73
Jabba is offline   Reply With Quote
Old 07-21-2004, 05:20 PM   #14
Vienna , Virginia
Hmm, a day with Por-15 Black Velvet and a wire brush is sounding more and more tempting...Thanks to all for the suggestions!
Mary
Propane camp stove? maxandgeorgia On The Road... 10 06-10-2009 11:28 PM
Stove jeanarlene Stoves, Ovens & Microwaves 25 08-27-2004 09:39 PM
Traveler Stove: valve? pilot? hello? is this thing on? Slik Stoves, Ovens & Microwaves 2 06-13-2004 03:59 AM
Drip behind cook stove Theo Plumbing - Systems & Fixtures 12 01-15-2004 10:07 PM
GrandMa's Stove 77caravaner Stoves, Ovens & Microwaves 0 10-08-2002 06:05 PM
