Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 11-02-2006, 09:09 AM   #1
Profile:  1971 31' Sovereign
Joseph , Oregon
Stove/Oven
Does anyone know of a resource for used stove/oven
Nicole and Larry
trea is offline   Reply With Quote
Old 11-02-2006, 09:42 AM   #2
newbie
audiobox's Avatar
Profile:  1970 21' Globetrotter
1987 34' Excella
Portland , Oregon
We'll be pulling the stove/oven (which is in nice condition) in our '87 Excella as we re-furb the interior, but it probably won't be until this coming Spring.
Craig
http://www.shinytrailer.com
audiobox is offline   Reply With Quote
Old 11-02-2006, 09:47 AM   #3
sequoiacoast's Avatar
Profile:  1968 24' Tradewind
Eureka , California
I saw a cool turquoise cooktop on ebay! Have you looked into craigslist and ebay?
sequoiacoast is offline   Reply With Quote
Old 11-02-2006, 10:11 AM   #4
SmokelessJoe's Avatar
Profile:  1976 Argosy 24
TORONTO and Southwestern , Ontario
Stove Oven available
Nicole and Larry:
I have not yet got around to listing everything that came out of my immaculate, one owner 1976 Argosy.
You can check my thread at:
ttp://www.airforums.com/forums/f227/contemporizing-1976-argosy-d-opinions-please-18448.html
The Magic Chef stove-oven looks hardly used at all and is available.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 11-02-2006, 12:27 PM   #5
Profile:  1966 17' Caravel
Seattle , Washington
Send a message via AIM to kitchenclose
Stove/Oven in Seattle, WA
Hi,
My stove/oven combo came out of a 1966 Caravel. All knobs, racks and elements are intact.
Please PM for more info.
Karen
kitchenclose is offline   Reply With Quote
Old 11-02-2006, 12:41 PM   #6
Safari64's Avatar
Profile:  1964 22' Safari
Eagle River , Alaska
1977 Magic Chef / free in California
I have Buttercup's old 77 Overlander Magic Chef stove/ oven.
It's free to a good home. I can't ship it.
I'm in Alaska, it's located in Northern California.
I'll be in CA late November.
Safari64
Safari64 is offline   Reply With Quote
Old 11-02-2006, 12:47 PM   #7
Blu_Hwy_Lady's Avatar
Profile:  1972 23' Safari
Placitas , New Mexico
Speaking of Magic Chef ovens...
On Airylle's maiden voyage I discovered that the thermostat must not work because the oven just gets hotter and hotter. I got an oven thermometer to confirm this. I started cracking the oven door open with an oven mitt to maintain a temp around 350. Unfortunately, with the door cracked, the knobs melted. Anybody have any experience replacing the thermostat or have a line on just the knobs.
Airylle 1972 Safari featured for 5 nanoseconds in the movie Wild Hogs
?Looking for a tow vehicle?
and
Jupiter (the Golden Retriever)
Athena (the road kitty)
Blu_Hwy_Lady is offline   Reply With Quote
Old 11-02-2006, 01:55 PM   #8
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
Another Magic Chef problem
Anyone else have trouble with galling valves? When the oven gets warm, or I use the front center burner (3-burner model, about 1999 vintage), the center burner valve freezes up. I assume because it's warm (I don't think it is very hot when this happens). Very dangerous and I get the run-around from the vendor.
Zep
Current 6-word memoir: Airstreams and Kayaks, a perfect match.
www.mindseyephoto.com www.airstreamdoctor.com www.pygmykayaker.com
Old 11-12-2006, 06:44 AM   #9
Commercial Vendor
Profile:  Currently Looking...
east stroudsburg , Pennsylvania
Zep
The valves need to be disassembled and regreased, there is a special grease available just for gas valves. You can buy it thru any commercial cooking equiptment service agency's.
RV_cool is offline   Reply With Quote
Old 11-06-2006, 08:30 PM   #10
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
Blu Hwy Lady,
Believe this qualifies as thread hijacking. Anyway, you can adjust the oven in your trailer to lower the temperature. About 100 degrees either way to keep the problem from happening. In the middle of the oven temp. knob (pull it off) is a small screw that can be turned to lower the temp. in your case. PM me if you need the instructions - they are in the 72 service manual if you have one.
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 04-12-2007, 01:06 AM   #11
eikel1we's Avatar
Profile:  1975 25' Tradewind
, middle of the mitt
Send a message via AIM to eikel1we
Magic Chef Gone Wild
Originally Posted by Ganglin
Blu Hwy Lady,
............ you can adjust the oven in your trailer to lower the temperature. About 100 degrees either way to keep the problem from happening. In the middle of the oven temp. knob (pull it off) is a small screw that can be turned to lower the temp. in your case. PM me if you need the instructions - they are in the 72 service manual if you have one.
I'm having the same problem with my oven. (The stove top is fine) I tried to use it for the first time since we've owned it and found no control over the temp. At any temp setting the oven heated to 550* or more. The top edge of the oven door was so hot I nearly burned my arm. The burner/broiler near the bottom of the oven had a flame the size of Rhode Island spreading out from it.
The camper center says it needs a thermostat .... and the parts are no longer available from Magic Chef. (Cupcake is a 1975)
Now What??
sue
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
2004 GMC Yukon XL 2500
Michigan - "middle of the mitt"
eikel1we is offline   Reply With Quote
Old 04-12-2007, 02:39 AM   #12
pamelake's Avatar
Profile:  1974 25' Tradewind
Lake Oswego , Oregon
Nicole and Larry, I was just in a place in Portland called Laurelhurst Heat and Air. 56th and SE Burnside. (503-236-2679) They had lots of 3 burner Magic Chefs and other brands. They also had one 4 burner Magic Chef in great condition, looked as if it had never been used. All are around $200.00. I was just looking for help cleaning mine up. The front shop guy didn't want to help because he wanted me to buy a new one, but one of the repairmen came out and was very helpful showing me how to remove the oven door. BTW, I will probably have to start a new thread about this soon, I was able to get the door halfway off with his instructions. Hope you find what you need. Pam
pamelake is offline   Reply With Quote
67 Safari renovation moogie32 1966 - 1968 Safari 151 06-13-2007 01:54 AM
1971 Overlander Stove/Oven? soldiermedic Stoves, Ovens & Microwaves 5 10-28-2006 09:13 AM
1999 Airstream Safari For Sale heyskipper For Sale & Wanted 7 08-31-2003 03:36 PM
Gas Leak???--help!! christiandpatrick LP Gas, Piping, Tanks & Regulators 14 04-05-2003 11:17 PM
Confusion-1957 bubble parts smallfry General Interior Topics 5 11-21-2002 06:09 AM
