09-05-2015, 07:54 AM
2012 25' Flying Cloud
Berlin
, Maryland
Stove fan and lights quit
I had the stove's overhead lights and the exhaust fan on this morning when they just quit. All other electrical is working in our 2012 AS so am wondering is there a separate fuse somewhere in that unit?
09-05-2015, 08:02 AM
Biloxi
, Mississippi
Check the fuses in your converter.
MICHAEL
09-05-2015, 08:56 AM
Berlin
, Maryland
I found it u have to remove the screen filter an it is on the upper right side. The fuse was blown will have to replace it
09-05-2015, 08:59 AM
Biloxi
, Mississippi
Excellent , glad it was an easy fix. Electrical problems can be such pita sometimes.
MICHAEL
09-05-2015, 10:13 AM
1974 Argosy 20
Kooskia
, Idaho
I seem to recall that the fuse was somewhat undersized to begin with and you may need to install a larger one than original.
Now, this is a vague memory, not sure of it.
09-05-2015, 10:19 AM
Biloxi
, Mississippi
Seriously, be careful upsizing fuses. That can have nasty consequences.
MICHAEL
09-05-2015, 10:28 AM
jackson center
, Ohio
3 amp fuse was original,company approved going to 5 amp. The issue was turn both light and fan on at same time.Another solution was going to Led light bulb.
09-05-2015, 10:32 AM
1977 31' Sovereign
Lynnwood
Generally speaking, fuses blow for good reason. If it blows again, it means you've got an electrical problem somewhere in that circuit.
Tom
09-05-2015, 11:05 AM
2012 27' Flying Cloud
San Angelo
This was a big deal for at least the 2012 models. Both Airstream and the fan manufacture acknowledged that the fuse installed was undersized. Ours did the same thing and after replacing it with the 5amp fuse (I think), in three years never popped again. Of course, another solution with the 3 amp fuse is don't use the fan or lights at the same time.
09-05-2015, 12:06 PM
Berlin
, Maryland
I have found a replacement fuse, not sure why it blew. but it was the first time in 3 years.
Again thanks for everyone's ones assistance
09-05-2015, 01:39 PM
2012 30' Flying Cloud
San Antonio
Replace the blown fuse with the mini GMC-5, time delay fuse. The stock fuse is European and 3.15 amp for up to 250 volt. That is the same as a 6.3 amp for 120 volt service. Thus a 5 amp mini is appropriate.
09-05-2015, 01:44 PM
1974 Argosy 20
Kooskia
, Idaho
I am glad my memory was not too defective and that there was a factory approved fuse size change solution for the problem.
I don't advocate a willy nilly change in fuse sizes, but I did recall that there was something posted on this issue in the past.
09-05-2015, 03:23 PM
Berlin
, Maryland
Well I replaced the fuse but it did not fix the problem. The lights came on but when I turned the fan on the fuse blew. Not sure if I should go to a higher fuse like some of the older threads say to do.
09-05-2015, 03:52 PM
2010 30' Flying Cloud
Pearland
Exhaust Fan & Lights
Remove the screen from under the hood. In the top right corner is a fuse. It is a small fuse and it is stocked at Radio-Shack. I don't have the part # handy, sorry. There is a problem with this unit. It seems you cn't use both functions at the same time. I've heard from others with the same problem that it is a manufacturing defect. I plan to ask the factory about it when we visit next summer. Hope this helps.
Dave
09-05-2015, 06:00 PM
Berlin
, Maryland
I am concerned that it is more as I have been using the lights and fan together for four years without any issue. So I wonder y it is happening now.
Anyway if u remember the part number I would greatly appreciate it.
John
09-06-2015, 11:43 AM
San Antonio
What is the number of the replacement fuse you used?
09-07-2015, 04:26 PM
Berlin
, Maryland
Not sure however they did not work. When I get back home I will look for a 5 amp and see if the fan works. If it does not then I believe I have a bad fan switch
09-08-2015, 10:18 AM
San Antonio
Try this one: mini GMC-5, time delay fuse
09-08-2015, 10:31 AM
Berlin
, Maryland
Thank you I will go to Radio shack or HD to see if they have them.
09-09-2015, 09:05 AM
San Antonio
