Old 09-05-2015, 06:00 PM   #15
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I am concerned that it is more as I have been using the lights and fan together for four years without any issue. So I wonder y it is happening now.
Anyway if u remember the part number I would greatly appreciate it.
John
urnmor is offline   Reply With Quote
Old 09-06-2015, 11:43 AM   #16
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Originally Posted by urnmor View Post
Well I replaced the fuse but it did not fix the problem. The lights came on but when I turned the fan on the fuse blew. Not sure if I should go to a higher fuse like some of the older threads say to do.
What is the number of the replacement fuse you used?
Howard L. is offline   Reply With Quote
Old 09-07-2015, 04:26 PM   #17
urnmor's Avatar
Berlin , Maryland
Not sure however they did not work. When I get back home I will look for a 5 amp and see if the fan works. If it does not then I believe I have a bad fan switch
Old 09-08-2015, 10:18 AM   #18
Howard L.'s Avatar
San Antonio , Texas
Try this one: mini GMC-5, time delay fuse
Old 09-08-2015, 10:31 AM   #19
urnmor's Avatar
Berlin , Maryland
Thank you I will go to Radio shack or HD to see if they have them.
Old 09-09-2015, 09:05 AM   #20
Howard L.'s Avatar
San Antonio , Texas
GMC5 | GMC Time-Delay Fuse: 0.197 in x 0.788 in, 5A, 125VAC, glass, 5/pk
This is it on line.
Old 09-09-2015, 09:11 AM   #21
Howard L.'s Avatar
San Antonio , Texas
Originally Posted by Howard L. View Post
or, ACE hardware has them--if you can find an ACE store.
Old 09-09-2015, 09:19 AM   #22
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
There is also a chance that the wiring is chaffing against the aluminum behind where the black fuse box is located above the filter. I had to put some tape on the chaffed wires on my 2012 Signature. I also replaced the fuse with a 5 amp and put in a LED light. All works perfectly now. No electrical jig required. Jim
Jim Flower is offline   Reply With Quote
Old 09-09-2015, 04:36 PM   #23
urnmor's Avatar
Berlin , Maryland
Howard thnks for the Link. I went to my local electrical store and he is ordering me some will be here tomorrow. All of the others i have tried have failed lthought they were not time delayed.
Old 09-09-2015, 04:38 PM   #24
urnmor's Avatar
Berlin , Maryland
Jim Thanks for the info. If the new fuses don't work that will be my next step.
Old 09-10-2015, 07:35 PM   #25
urnmor's Avatar
Berlin , Maryland
Success. The new time delayed fuse solved teh problem
Old 09-11-2015, 08:54 AM   #26
Howard L.'s Avatar
San Antonio , Texas
success. The new time delayed fuse solved the problem
'71 Tradewind vent fan help.Low speed quit. Wooden Rivet General Repair Forum 5 04-07-2014 04:47 PM
Bath exhaust fan quit TY PECK Sprinter and B-van Forum 3 10-17-2012 05:56 AM
Fan Wont Quit Running? Help! CalamityJane Electrical - Systems, Generators, Batteries & Solar 12 07-23-2012 05:19 AM
Lights quit working after plugging cell phone charger into cigarette lighter hagnik Lights - Interior & Exterior 6 06-20-2011 09:57 AM
Fantastic Fan quit - what should I check dufferin Roof Vents, Skylights & Fans 5 10-12-2007 06:25 PM
