Old 07-26-2002, 03:30 PM   #1
jeanarlene
1971 23' Safari
Lake Ann , Michigan
Stove
The stove in my '71 Safari doesn't work. The Airstream dealer was unable to get parts. I will reluctantly have to buy a new one. I will hire a local RV repair man (the Airstrem dealer is too far away)but he said it will be a difficult job because he will have to cut the old formica counter and it likely will crack. Has anyone had experience puting in a new stove? I'd be happy with a used one if I could find one. It might not require as much adaptation.
Jeanarlene
jeanarlene is offline   Reply With Quote
Old 07-26-2002, 03:35 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I am sure you could find a used one, but the cost to get it to you may be steep. In the vendors section is contact info for a place called colaws salvage that may have a used model of what you need. Then it would be a simple R&R and no modification necessary.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 07-26-2002, 08:50 PM   #3
LOST , Hawaii
They might even have the parts, would be a lot cheaper than shipping the whole stove.
John
74Argosy24MH is offline   Reply With Quote
Old 07-27-2002, 06:54 AM   #4
jeanarlene
1971 23' Safari
Lake Ann , Michigan
Thanks for the tips. I'll look for the place suggested in the vendor list. I was told that the oven valves were shot and need to be replaced. One RV repair place said it was against the law to fix old gas stoves because of safety hazards. The only way I can decide what to do is to get a variety of opinions and then compare them. I give more weight to advice through this forum than to those from RV places looking to sell new replacements.
Jeanarlene
Old 07-27-2002, 07:16 AM   #5
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Even though it is an RV model you may wany to contact an appliance repair shop in your area. A second opinion is usally worth the time and money. Especially before you start cutting into counters.
Brett G
Old 07-27-2002, 07:17 AM   #6
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Let us know what exactly is wrong and we can try to guide you to the proper places.
Which stove brand and model do you have? Look on the manufacturers plate and get the model number off of it.
It is not illegal to repair old gas stoves. What should be illegal is repair people telling you that.
There are a number of parts dealers who specialize in old parts.
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 07-28-2002, 12:50 PM   #7
jeanarlene
1971 23' Safari
Lake Ann , Michigan
Stove
Someone suggested getting the stove looked at by an applicance repair place and that gave me an idea. I might find a regular apartment size gas range which could fit the space. I've decided I should replace the current stove (instead of trying to find parts for it) as it's very rusty and pitted. At a local appliance dealer I found a gas range that fits the space and costs half of those in RV cats. The only problem was the oven pilot has to stay on all the time and it was set up to be used with natural, not LP, gas. I haven't looked at other brands yet so don't know if this is true of all. Has anyone put in a regular gas range instead of the specialized RV brands? Is it feasible?
Jeanne
Jeanarlene
Old 07-28-2002, 01:41 PM   #8
LOST , Hawaii
If you find one that will fit, that would work. But is has to be LP, or converted to LP.
John
Old 07-28-2002, 04:32 PM   #9
jeanarlene
1971 23' Safari
Lake Ann , Michigan
I think getting the gas range converted to LP might not be a big thing but if the oven pilot has to remain on all the time--that could be a problem. Would it be a hazard traveling with the pilot on in the oven? I haven't pulled a trailer in years and forget a lot. Don't we keep the gas reefer on while traveling? Should we turn off the LP tanks while traveling? If so how would that effect the pilot in the oven which is supposed to always be on? What's the thinking on that these days?
JD near Traverse City, MI
Jeanarlene
Old 07-28-2002, 05:24 PM   #10
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Propane stove
A propane stove pilot is a bit different than a natural gas pilot. The propane stove pilots that I have seen have a sensor like on the water heater that shuts off gas to the pilot depending on a thermocouple. These pilots can be turned off just like the water heater or a RV stove.
It usually requires a kit for $50 or so to change a natural gas appliance to propane. The kit has different orifices and the control.
John W. Irwin
WBCCI #9632
Old 07-28-2002, 05:39 PM   #11
jeanarlene
1971 23' Safari
Lake Ann , Michigan
Does the converter for propane to LP have the safety feature of the sensor? If not, I guess I'd better buy an rv LP stove.
Jeanarlene
Old 07-28-2002, 06:32 PM   #12
is the stove in your trailer a 1 piece or 2 piece?
sudden impact is offline   Reply With Quote
Old 07-28-2002, 06:44 PM   #13
Pahaska's Avatar
Hays County , Texas
Safety feature
Yes, that is the major part of the kit that changes a natural gas appliance to propane. That is why the kits cost a few dollars. The orifices are trivial cost.
John W. Irwin
WBCCI #9632
Old 07-28-2002, 08:44 PM   #14
2002 34' Classic S/O
Irvine , California
Images: 11
We are going through the same issue. We just bought a '75 Overlander. The cooktop was shot, although the wall-mounted oven was OK. We opted to replace everything. C&G Trailer Service, in Bellflower, will remodel the cabinets and tambour doors to eccept a new range, he'll put in a new formica counter top, and remodel the "hole" from the wall oven to build in a new microwave oven. It's a chuck of money, but we'll be starting out with virtually a brand new kitchen. It seemed better than trying to find parts for really old and ugly appliances.
Good luck with yours!
Phil in Irvine
WBCCI # 9759
2002 34 Slide Out Lounge
2005 Yukon XL, 3/4 ton, 4WD, 8.1 engine
pjtaia is offline   Reply With Quote
Stove Hood Exhaust Cazadero Cabinets, Counter Tops & Furnishings 1 01-17-2004 05:57 PM
Drip behind cook stove Theo Plumbing - Systems & Fixtures 12 01-15-2004 09:07 PM
stove vent installation Martha Roof Vents, Skylights & Fans 4 02-20-2003 08:18 PM
Camping Stove Krazykraut LP Gas, Piping, Tanks & Regulators 3 12-17-2002 01:41 PM
GrandMa's Stove 77caravaner Stoves, Ovens & Microwaves 0 10-08-2002 05:05 PM
