Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 02-20-2009, 11:15 PM   #1
Profile:  1976 31' Sovereign
Blairsville , Georgia
Small Part for Magic Chef
My '76 31' rear bath has a four burner Magic Chef range. There are four tubes, one going to each burner from the pilot. The tubes are in two pieces with the section at the pilot end being steel and the section that connects to the burner being aluminum. I need one of the aluminum sections. Mine was missing when I got the trailer. Does anyone have a junk stove from which they would sell one of these tubes. I could use just the aluminum ppiece or the whole two piece tube. Thanks for any help.
Chip Arnold is offline   Reply With Quote
Old 02-21-2009, 08:14 AM   #2
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
I have some In a box, Could you post a pic of what you need and I will see if they are the same. Mine came out of a 68' ambassador 4 burner. If they work you can have them for the shipping cost.
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 02-21-2009, 09:45 AM   #3
Hi Jason, Thanks for your response. I don't know how to post a picture but I'll try for an accurate description. The tube is made up of two pieces. A steel piece which is 2 1/4" long and an aluminum piece which is 3 1/2" long. The alum. tube slips into the steel tube so that the overall length when mounted in the stove is approx. 4 3/4". One end of the alum. piece is cut square. The other end, which attaches to the burner, is cut away top and bottom for a distance of 1/2" to 3/4". I have the steel part and only need the aluminum part.
If you aren't sure if this is what you have but even think it might be, I'd be happy to send you shipping, time and trouble money for it on the chance that it would work.
Thanks again,
Chip Arnold
Old 02-22-2009, 10:15 AM   #4
All, Jason's parts turned out to be not the part I need. The tubes I'm speaking of are for the top four burners, not the oven. They are not attached by fittings, they just go from the pilot light out to each of the four burners and are held in place by a small length of spring wire. I only need one.
Old 04-05-2009, 01:34 PM   #5
I just want to report that thanks to member Don (adonh) we have our stove up and running just fine. There is a wonderful group of people on this forum. Thanks!
Old 08-19-2009, 06:32 PM   #6
Profile:  1970 27' Overlander
carson City , Nevada
aluminum thingees
Yes.. I need two of these as well cannot find them anywhere
zenarmy is offline   Reply With Quote
Old 10-16-2009, 11:48 AM   #7
wbt
Profile:  1978 31' Sovereign
Washington , Missouri
I have a '78 31' Sovereign- Found the burner end of the "flash tube" at Bill Thomas Camper Sales at Wentzville, MO. 636 327 5900/ 800 367 5767. Part # 74003326 (FSP/Whirlpool). Expensive, but available at 10.00 each. Talk too; "Beth".
a
wbt is offline   Reply With Quote
Old 10-16-2009, 12:15 PM   #8
Power to the People !
Maryw164's Avatar
Profile:  1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
There is a posting in the classifieds here on the forums for Magic chef parts. Have you checked there?
Magic Chef Stove Parts - Airstream Trailer & Airstream Motorhome Classifieds
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
http://www.airforums.com/forums/blog...-maryw164.html
http://1972airstreamsovereign.blogspot.com/
Maryw164 is online now   Reply With Quote
Magic Chef Oven danesh Stoves, Ovens & Microwaves 34 03-31-2009 03:21 PM
Magic Chef Stove Stone Ridge Stoves, Ovens & Microwaves 8 02-18-2009 08:15 AM
Magic chef Oven Joyce K Glass Stoves, Ovens & Microwaves 4 03-15-2008 12:34 PM
Magic Chef Range Dtrmnd Stoves, Ovens & Microwaves 0 02-06-2008 02:14 PM
Magic Chef parts walter1 Stoves, Ovens & Microwaves 0 09-23-2007 03:36 PM
