Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 12-03-2015, 09:32 AM   #1
John Gervais's Avatar
1998 25' Safari
Orléans , Ontario
Slide-in stovetop replacement
I have a 1998 25' Safari. I need to replace the existing original Maytag slide-in stovetop (no oven) model CLZ8502BDB. I would like to simply take the old one out and slide in the new one without having to do any carpentry work. The original model is not available any more. So far I found that the Suburban model 3100A might do the trick (the dimensions quoted are the same as the existing dimensions on the countertop).
Any suggestions?
John Gervais is offline   Reply With Quote
Old 12-03-2015, 10:08 AM   #2
cameront120's Avatar
1972 25' Tradewind
I'd contact Suburban and ask them to send you a cut sheet that shows all dimensions and installation notes (if they aren't available for download). Then it's a matter of getting inside the trailer, removing the Maytag and confirming that the suburban will fit in the vacant space, based on the dimensions and installation notes. Hopefully the void is close enough that it will need little or no modification.
North Vancouver, BC
Replacement StoveTop mark.s 1965 - 1969 Overlander 3 01-04-2016 02:27 PM
Slide In vs. Drop In Stovetop Roadrunner Stoves, Ovens & Microwaves 1 02-19-2013 07:39 PM
Paint stovetop with high temp paint? scooterpie Stoves, Ovens & Microwaves 4 02-19-2006 03:47 PM
where can i find a new stovetop roadtrip07 Stoves, Ovens & Microwaves 1 07-13-2005 02:11 PM
Stovetop & Hubcap lmbando 1974 - 1979 Sovereign 5 08-16-2004 09:39 PM
