10-07-2015, 02:48 PM
2010 25' FB International
Lake Arrowhead
Sharp microwave convection turntable size & material?
I'm cleaning up our previously loved 2010 Int'l and it's missing the turntable in the Sharp R820BKF convection microwave. Can anyone who has this model tell me the measurement of the turntable and if it's glass, ceramic, or metal? A new replacement is $65 shipped and I'm hoping to find something suitable at the thrift store. Thanks!
10-07-2015, 03:29 PM
2014 25' Flying Cloud
Cuddebackville
, New York
it's metal and 12.75" in diameter.
2019 Ford Expedition Platinum
10-07-2015, 03:34 PM
Biloxi
, Mississippi
Interesting, mine is 12 5/8 and glass.
MICHAEL
10-07-2015, 04:32 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
The glass turntables are pretty much standardized throughout the industry. I've had microwaves at home from three different manufacturers that all had identical Pyrex turntables in them, and every time I discard a dead microwave, I save the turntable just in case; the spares also do double duty as serving trays. They're too big to fit a Sharp convection microwave because they're all from bigger units for my home so I can't just ship you one, but same principle should apply for the smaller microwaves; they should have interchangeable turntables. I would think that if you can find a same-size microwave from any manufacturer, the glass turntable from that microwave will probably fit yours.
The metal tray goes on top of the glass turntable when you're cooking with convection. When you're cooking with microwave only, you only use the glass turntable. Since the metal tray isn't really breakable, I assume the glass turntable is what's needed in this case.
To keep my glass turntable in my Airstream from breaking in transit, I carry paper goods in the microwave— paper towels, paper plates, paper napkins. If there's room left over I'll stuff some cloth placemats in there for additional padding.
10-07-2015, 04:37 PM
Lake Arrowhead
Thanks everyone. It doesn't have any type of tray in it now, so I guess either glass or metal will work. I'll look at the thrift shop this weekend.
10-07-2015, 04:44 PM
From All Over
No! You must have the glass tray. The metal tray is only for convection cooking, and only when set on top of the glass turntable. If you use the metal tray without the glass turntable you'll damage the microwave oven.
If you only get a glass turntable you can only microwave. If you get both the glass turntable and metal tray you can microwave or convection cook. If you get only the metal tray you can't cook anything.
10-07-2015, 04:48 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
shoot Pro... mine has only a metal turntable and I've used it for a year without a problem. May be ceramic coated?
Paula
10-07-2015, 05:33 PM
From All Over
Could be. All I know is the owner's manual for my Sharp microwave/convection oven in my Airstream was very emphatic in stating that the metal tray is only to be used with the glass turntable under it. The metal tray doesn't turn by itself— it has three wire feet around the edges and doesn't engage the turntable spindle in the center— so maybe that has something to do with it?
10-07-2015, 06:09 PM
1968 22' Safari
Buda
Mine only has a metal tray and a metal rack above that. No glass came with it....no glass required....no glass necessary...all works fine with metal, both convection and microwave. Been working that way since we started full timing in our Airstream 4 months ago
Sent from my iPhone
David & Diane
DFlores
David & Diana
10-07-2015, 08:09 PM
From All Over
Just to be clear, you're talking about a Sharp microwave/convection oven, like in TamiB's original post? I wasn't aware that Sharp made any microwave/convection ovens without a glass turntable. Guess I still learn something new every day.
10-08-2015, 08:50 AM
Curtis Wright
Eyren Haven
, South Jersey
what a go. I didn't even know we could use metal in a microwave. Should have seen the fireworks when I forgot a spoon.
10-08-2015, 10:57 AM
1955 18' Globetrotter
Carrollton
Sharp Microwave convection turntable size and material?
Manual shows turntable assembly as measuring 12 & 3/4 "
Manual found thru "google" on this particular model.
10-09-2015, 06:18 AM
2012 23' FB International
Woodstock
, Ontario
I don't see how a metal tray on the bottom is a problem for Microwaves. The whole unit is metal; top, bottom and sides. Microwaves go through glass but not steel.
The metal tray is probably to protect the glass from the heat stress of hot glass and (until cooked), cold food. Our convection microwave in our Texas park model had a glass turntable which I have used for baking with convection but usually Pillsbury things and anything needing to be baked always went in a metal dish because that's the usual way to bake.
The problem with Corning is that is probably isn't "Corning Ware". The Chinese purchased the "Corning" trade mark and cheapened the glass by eliminating the Borosilicate. So if instructions say remove glass for baking, that is probably the reason.
JCW
10-09-2015, 07:36 AM
2008 25' Classic
Full Time
Just spend the $65 and get the correct part. Why spend time and money trying to find something that might not work.
Kelvin
10-09-2015, 07:48 AM
2005 30' Classic
Burlington
, Ontario
The glass tray in 2006 AS Dometic microwave microwave broke a couple of years ago when on a trip.
I checked at Camping World for a replacement and they told me they could order a new one for about $70 - plus I would have to pay some exorbitant amount for shipping.
Instead, I tried a few local charity shops and found all kinds of microwave trays that seems as though they should work for a coupe of bucks each.
Turn out however that the drive on the Dometic uses a sort of three legged spider with wheels on the ends. The glass needed to have a "track" molded in to match the radius of the wheels and without that, they trays I found would not work properly as the tracks they had were slightly different.
I thought about modifying the spider to change the radius of the wheels, but a search on the internet suing the model number of our microwave turned up a place in California where I was able to buy the correct replacement for about $20. Shipping was not expensive.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
10-11-2015, 03:58 PM
2008 31' Classic
Raymond
, Nebraska
Sharp Turntable
Tami B - I have the metal turntable that you need. It's the right size for your model. We got a new Sharp Micro- Convection and found that the turntable is different from the old one. Gladly will let you have it for the cost of shipping. jdbasutton@gmail.com
