Old 05-22-2010, 09:50 AM   #1
1965 26' Overlander
Zanesville , Ohio
Replacement Range Hood Motor
Hi All,
I'm into the range hood in my 65 Outlander and I have found that the blower fan assembly is missing..for whatever reason. Nothing there except the steel shell. What are my options for a replacement fan for my hood? Is it just a basic blower fan for an RV application? Thanks in advance.
Chris
Hihosilver2 is offline   Reply With Quote
Old 05-22-2010, 11:35 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Check this out, may what you need.
Motor for Airstream Galley and Overhead Vent 510228 [510228] - $64.95 : ODMRV , Out-of-Doors Mart
Old 05-23-2010, 08:51 AM   #3
1965 26' Overlander
Zanesville , Ohio
Originally Posted by 68 TWind View Post
Thanks for the reply 68 TWind. Looks like possibly half of what I'm after. All I have in my hood unit is just the sheetmetal hood. No motor, fan to attach to motor, and I'm assuming bracketry to hold the motor inside the hood? I'll need to look at my hood again to check on that. I wasn't very clear I guess about needing a bracket also. Thanks!
Chris
Old 05-23-2010, 09:17 AM   #4
mandolindave's Avatar
While we are on the topic
Hi Chris,
My hood fan is way LOUD. I am betting it uses a lot of juice too. I am not keeping my trailer original. Maybe you could ask the forum people if anyone has found a good, quieter system of venting the stove.
I almost wish I was missing my hood fan , so that I could justify
buying a better system Ha Ha. Dave
mandolindave is offline   Reply With Quote
Old 05-23-2010, 02:18 PM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Originally Posted by mandolindave View Post
Hi Chris,
In stead of buying a new system it was posted here on another thread about adding a resistor to the switch, it works, motor runs at half the decibels and still pull out air.
Back to the original post, most hoods seem generic, so you might find what you are looking for at RV surplus or recyclers at a better price. since you need brackets too. and a simple motor replacement won't work.
Baraldi Range hoods, The Stainless steel Range hood found in 2009 Airstreams AeryCorp Commercial Listings 18 05-10-2016 01:41 PM
Range hood 67twinkie Stoves, Ovens & Microwaves 24 04-06-2015 10:30 PM
Range hood question Bigventure Roof Vents, Skylights & Fans 1 11-18-2009 11:05 PM
does anyone know of a range hood that... Julie R Stoves, Ovens & Microwaves 12 08-13-2007 10:00 PM
Range hood C Johnson Stoves, Ovens & Microwaves 0 05-30-2005 01:35 AM
