Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 08-11-2012, 03:18 PM   #1
ncairstreamr's Avatar
2023 20' Basecamp
Lincolnton , North Carolina
Images: 11
Replacement Microwave for 2007 Safari 23 SE
I need to replace the built-in Tappan TM 9030 B microwave that came with my 2007 Safari. Because I'm having a difficult time locating that particular microwave locally, I'd appreciate advice on replacement microwaves of the same dimensions that can be installed using the same faceplate. Thanks.
ncairstreamr is offline   Reply With Quote
Old 03-02-2013, 06:39 PM   #2
2007 25' International CCD
Redmond , Washington
Need Owner Manual
I have the same Tappan, no owner manual. Can I get a scan of yours? Or have you send it to me if you're replacing it? Thanks.
dalestirn@gmail.com
Cannondaler is offline   Reply With Quote
Old 04-28-2013, 08:35 AM   #3
2007 23' Safari SE
Windsor , Connecticut
I can't help but wonder why you had to replace your microwave so soon. I have the same model airstream trailer and am looking to fix or replace my microwave also. The microwave works except it turns on by itself. The door switch is getting tripped; the door seems to be hanging too low.
Borias53 is offline   Reply With Quote
