Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 11-14-2016, 10:01 AM   #1
chilipepper's Avatar
1971 27' Overlander
Dickinson , North Dakota
Replacement Magic Chef Oven Timer - 1971
My time on my 1971 Magic Chef wall mounted over is foobar. Has anyone found a suitable replacement for the original one? I tried a few from the hardware store that I though I could retrofit but without any luck. So if you have found a particular replacement that would work that would be great too.
Any help would be greatly appreciated!!
Ryan Jilek
WBCCI 7165 | TAC ND-3
Ms. Streamy - 1971 Overlander Restoration Blog
chilipepper is offline   Reply With Quote
Old 02-27-2017, 06:05 AM   #2
1971 31' Excella 500
Burlington , North Carolina
I have the same problem. It still works without the timer? I just bought the camper and haven't tried it yet. I found an oven down the road in nc for $70 and everything works. I don't know where you are located.
Scoobyct12 is offline   Reply With Quote
Old 02-27-2017, 07:44 AM   #3
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
Palm Desert , California
I have a spare timer that didn't work so I opened it up. There's a plastic gear and all the teeth have broken off. Now I see is why it doesn't work. I bought a replacement oven and it has a working timer but I won't use it now knowing there's a plastic gear inside.
CaCraig is offline   Reply With Quote
Old 02-27-2017, 10:11 PM   #4
1971 27' Overlander
Thanks for the replies.. My guess is the same. The teeth on the plastic gear become brittle with heat and time and probably are not worth the effort. I've been looking and trying to fine another mechanical timer from a kitchen store or somewhere. IF a person could find a newer version that has a similar setup maybe there is a way to retrofit it in the old spot with the original knob.
I have not come across anything yet but still looking!
Ryan Jilek
Old 04-26-2017, 12:10 PM   #5
I found an old robertshaw kitchen timer on ebay from the 50s. Got it for $20 and it fit. Has a metal gear. Look at the back of the timers and make sure it has the three nuts holding the bell.
Old 04-26-2017, 10:15 PM   #6
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
The original knob fit?
Thanks for the tip!
Discolored oven door glass on Magic Chef oven Ahzmyrah Stoves, Ovens & Microwaves 2 08-26-2020 08:21 AM
Oven Magic chef lamp light replacement brunoffrance Lights - Interior & Exterior 0 07-14-2015 05:56 AM
Burner/diffuser ring Magic Chef oven from 1971 Safari edirwin Stoves, Ovens & Microwaves 0 03-02-2010 01:46 PM
Magic Chef needs magic fix Sheridan Stoves, Ovens & Microwaves 8 11-21-2009 03:44 PM
Magic chef Oven Joyce K Glass Stoves, Ovens & Microwaves 4 03-15-2008 11:34 AM
