Old 12-07-2012, 09:17 AM   #1
1967 26' Overlander
TOME , New Mexico
Replace oven with convection microwave?
Just wondering if this is a bad idea or not? The oven doesn't work, and I am thinking that a microwave would be more practical anyways. I'm just concerned about wiring and venting. I read in a past post that I wouldn't need to vent the microwave. But the wiring may be an issue depending on the wattage of the microwave? ANY input is gratefully appreciated!
guadalupegrl is offline   Reply With Quote
Old 12-07-2012, 10:14 AM   #2
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
We went the other way. We removed the convection microwave that came with the trailer and replaced it with a propane range/oven combo. My wife did not like the results from the convection microwave. We bought a small (.7 cu. ft, 700 watt) microwave that works great. Convection microwave did have a dedicated circuit wired to it from the factory.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 12-07-2012, 11:22 AM   #3
fr8tshaker's Avatar
2006 34' Classic
Sioux Falls , South Dakota
Why not both?
I have both for several reasons.
I can use the standard oven when not plugged in.
I use my Sharp Grill 2 convection when plugged in.
The Sharp does not require outside venting. There is a learning curve but the user's manual is very instructional. A 12 in. pizza placed directly on the metal turntable comes out perfect with a wonderful crispy crust. The Sharp grills steaks beautifully.
I also purchased a set of vintage Corning Ware NIB for less than $25 on ebay because it can be used on the stovetop, in the conventional oven, in the Sharp on either the microwave or convection setting. The Corning Ware has removable handles which is great for storage and makes the pans useable as skillets or casserole.
A lot depends on your cooking and camping style.
Hope This Helps,
'shaker
2006 34' Classic LTD
2010 Ford F250 PSD
Hensley Arrow Hitch
fr8tshaker is offline   Reply With Quote
Old 12-07-2012, 12:56 PM   #4
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
Our new trailer has the micro/convection combo. I am thinking about replacing it with the basic oven like the old trailers we had. The old oven worked when we were camping without electricity. The micro/convection does not. Since we do most cooking outdoors when we camp it isn't a big issue.
dkrug is offline   Reply With Quote
Old 12-07-2012, 02:28 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Grl,
Take a look at the many "do you use your oven" threads.
Broadly, the answer depends on where you camp and your style of camping, traveling, and cooking. In the desert southwest you can more or less count on being able to cook outside and if that's your thing maybe you don't need an oven. Those of us who live where it rains need plan B.
Old 12-07-2012, 03:53 PM   #6
2008 27' International FB
1999 19' "B" Van Airstream 190
Marietta , Georgia
We recently switched out our microwave/ convection oven for the regular oven. The controls and display on the convection/ microwave were too low and I found that I needed to kneel on the floor to see/ set the temp and time. Plus the controls were non- intuitive so I had to drag out the manual to figure it out each time. ( we're still working so our trips aren't as often as we'd like)
I'm much happier with the regular oven. We may get a small microwave for the closet but we may not. Haven't seen the need yet.
karenjude is offline   Reply With Quote
Old 12-07-2012, 09:14 PM   #7
Travel Bird's Avatar
2012 27' FB International
Denver , Colorado
I would never give up my oven!!!
Anna
Blog: Glamper~An Airstream Diary
www.glamperanairstreamdiary.com
WBCCI #4846, WBCCI DenCO Unit
Air #62992
Travel Bird is offline   Reply With Quote
Old 12-08-2012, 12:26 AM   #8
wolverine's Avatar
2005 31' Classic
Sunrise Beach , Missouri
We replaced our conventional microwave with a convection when we found a unit on sale during our tour of the Airstream factory. Since we primarily use our Airstream at campgrounds with electricity, we are very happy with it and find it has more features than conventional units. It fits in the same place as the original unit and does not require additional venting. It did come with a trim plate to surround the front of the unit.
wolverine is offline   Reply With Quote
Old 12-08-2012, 07:34 AM   #9
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Since we use a convection oven at home it was no biggy to use the one that came in our Safari Sport. My wife loves to bake and it does a superb job baking, roasting, making popcorn, or broiling a steak, somethings the propane oven just can't do well. If we are boondocking the Honda jenny takes care of the elecrical needs. We would never go back to the limited functionaliy of the propane oven. It is not vented but opening a window slightly and turning on the Fantastic fan works well.
Ahab is offline   Reply With Quote
Old 12-08-2012, 08:40 AM   #10
Whizzo's Avatar
2014 23' FB Flying Cloud
San Antonio , Texas
Images: 18
The factory convection microwave, combined with the usual gas burner cooktop, is a flexible combination, and does everything we need. We were skeptical about not having a normal oven like in our previous trailer, but in practice we haven't missed it.
We don't camp anywhere we don't have shore power, but if we did, the menu would just have to come from the stovetop!
2014 Flying Cloud 23FB
2015 Ram 1500 EcoDiesel
Whizzo is offline   Reply With Quote
Old 12-08-2012, 09:21 PM   #11
1967 26' Overlander
TOME , New Mexico
Talking thanks!
I think it is official... I will keep the oven, and also get a small microwave. Now to repair or replace the oven! Thank you all for your input, it is a true blessing to have found the site!
Old 12-09-2012, 08:17 AM   #12
Livingston , Texas
Your initial question was whether the wiring could handle it, wasn't it? Assuming you don't go crazy with a HUGE COMERCIAL MONSTER, there will be no issue with the wiring as long as you have it on a seperate circuit. We get a laugh out of people having issues with "convection" ovens not "cooking right" and prefering there "regular ovens to "them". A regular oven IS a convection oven!
pattydoug is offline   Reply With Quote
Old 12-09-2012, 12:19 PM   #13
fr8tshaker's Avatar
2006 34' Classic
Compact Microwave
Thought I would suggest this microwave for you and others with limited space. DH and I use this in our 18 wheeler. It is great for people that use their microwave to reheat food, coffee, or make popcorn. It is very lightweight, portable and stores easily. It is spendier than regular small home units but was worth it to us for the gains in space and portability.
Perfect Little Compact Microwave Oven, Best Portable Smallest Microwaves
We use a Nesco Oven (slowcooks,bakes, roasts), electric skillet, and Crockpot 20 oz. Food Warmer for about everything else while working on the road.
So if your use of a microwave is limited this may be a great solution.
'shaker
2010 Ford F250 PSD
Hensley Arrow Hitch
Old 12-09-2012, 03:54 PM   #14
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Does anyone have an Airstream factory Micro/Convection for sale? Please PM me so we can discuss it.
regards, BV
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
