Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 01-13-2007, 04:03 PM   #1
Profile:  2007 25' International CCD
Arlington , Virginia
Question Removing the oven/cooktop from a 25' Excella
Has anyone ever removed their oven/cooktop from their AS (non-professional removal)? How much trouble is it to do? I have an oven that was not used by the previous owners and I don't plan on using, so I want to remove it and replace with a smaller convection oven I can remove and put back in as we need it. I plan on having a 2-burner electric cooktop installed also.
Streamer1 is offline   Reply With Quote
Old 01-13-2007, 04:54 PM   #2
Kistler's Avatar
Profile:  2002 25' Classic
Oro Valley , Arizona
I like your idea; my wife doesn't use the oven--except for storage. I did not know that you could run an electric cook top on any less than 220??? AND it will only work when you are on shore power.
Kistler
Kistler
Brenda
Misty (Maltese)
Maxwell (grey tabby)
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 01-15-2007, 04:17 AM   #3
Commercial Vendor
Moonstruck's Avatar
Profile:  1986 31' Sovereign
Sherfield English , Hampshire
Send a message via MSN to Moonstruck Send a message via Yahoo to Moonstruck
Hi,
I had to remove the oven from my 86 Sov last week. I hope the process is much the same. Here goes:
SWITCH OFF THE GAS!
Looking at the oven you will notice that the sides of the oven sit proud of the counter top. On the inside edge of that raised trim you will see screw heads, on mine there were two on either side. Having removed them you will feel a little movement in the oven, but don't pull too hard because the gas pipe is still connected.
Remove the pan supports. Lift the stainless steel section of the stove top - Its hinged at the back. You should see the gas pipe running from the back of the unit to the front under the RH gas burners.
You will need two spanners: one to fit the supply head and another to lock the fitting on the oven fitting. If you don't lock this it will turn and the gas pipe will begin to twist.
Having undone the gas pipe, pull the whole unit out bodily. The supply cables have enough length to allow you to take the oven out. Dont twist the unit as it comes out, the gas pipe needs to be fed through the access hole at the back of the oven.
I find it useful to have a box for the oven to sit on - placed in front of the sink cupboard - this saves your back and ensures that no grubby oily stuff which might be on the oven gets on the floor.
Good luck AND DON'T FORGET TO SWITCH THE GAS OFF!
Marc
Coming soon: How to convert your twin to a double bed!
Silvertwinkie
Hampshire, UK
Moonstruck is offline   Reply With Quote
Old 01-17-2007, 11:14 AM   #4
Thanks Marc!
1974 excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 02:53 PM
81 Excella Cat 1981 - 1983 Excella 8 02-25-2004 11:44 PM
Removing wallpaper from 76 tradewind Rennegarbe1 Upholstery, Blinds, Walls & Interior Finishes 4 02-05-2003 05:52 AM
cost of 81 Excella new? jaiman General Motorhome Topics 7 11-09-2002 06:49 AM
78 Excella 500 davidz71 Our Community 2 10-17-2002 02:11 PM
