Old 04-03-2014, 01:00 PM   #1
1969 31' Sovereign
Rock Hill , South Carolina
Refrigerator help
I just bought a restored 68 Sovereign and the frig was a mess and we threw it out. Question, what would make the best choice for a replacement. At this time I only have 120 V power to the unit. What type does one buy to get it to run while driving?
popacliff is offline   Reply With Quote
Old 04-03-2014, 01:18 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
If you want to have the refrigerator operating on the road, you'd want either the original-type replacement (a 2-way propane/electric fridge like a Dometic or Norcold) or if you want to upgrade the 12v system some, especially if you're doing solar, a 12v Danfoss-compressor fridge like a Dometic Tundra, Novakool, Vitrifrigo, etc.
Propane fridges with the old-style venting like my trailer has (and I assume yours does) work pretty well. There are a few models available that work just like the old-school ones, requiring no 12v power at all. Most current propane/electric fridges need 12v DC to run the control board. The venting I'm talking about is an intake in the floor and an exhaust vent on the roof.
David
Old 04-03-2014, 02:03 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I found that there are slight difference in size between the current style refrigerators and the ones in 68. Can't remember exactly the difference in size, but Dometic makes a unit that is the correct size for the opening. Of course it cost more than the "standard" size but it fit the opening without me having to do a lot of cabinet work. Model is RM2510. I shopped around and found the best price at PPLMotorhomes.com in Houston,TX (they are very friendly and gave me great service on a number of different orders for various items I used during the restoration). You will need to make a panel for the front of the door and stain it to match the other wood in your 68. Finally, there should be a 12V wire in the area where the original fridge was located. You will need a 12 volt source and a 120V plug and of course the propane line. I had to run a new propane line as mine had been capped off at the main trunk line fitting under the trailer.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Gas Refrigerator help? zadaschwartz Refrigerators 14 05-04-2013 10:32 PM
HELP!! Bought new Dometic refrigerator--How do I remove the RM60? Shelby Copeland Refrigerators 6 07-17-2012 07:55 PM
Compact Home Refrigerator or RV Refrigerator? mattsteel Refrigerators 26 04-05-2011 01:30 PM
Dometic Refrigerator help needed UK-Airstream Refrigerators 8 05-25-2006 04:57 PM
Help!! Refrigerator Access Door Needed! Melissa Hamilton Exterior Storage Compartments & Access Doors 13 01-19-2004 04:03 PM
