Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 07-05-2012, 06:33 AM   #21
drew05's Avatar
2011 25' FB Flying Cloud
Peculiar , Missouri
drew05 is offline   Reply With Quote
Old 07-08-2012, 02:25 AM   #22
DMT
DMT's Avatar
2011 27 FB International
East Coast , Newfoundland
Fuse blew again. Something's up.
[AIR# 55762 TAC# NFL-1
DMT is offline   Reply With Quote
Old 07-16-2012, 09:31 PM   #23
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Check the wiring back into the wall. They rough cut the inside skin and do not protect the wires - chaffing will cause a short when towing. That's what I found with my heater when it kept blowing fuses. How much can a piece of rubber edge guard cost?
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 07-17-2012, 02:16 AM   #24
DMT
DMT's Avatar
Add that to Gene's suggestion thread.
Old 08-17-2013, 01:58 PM   #25
Powayegg's Avatar
2013 25' Flying Cloud
Livingston , Texas
Send a message via Skype™ to Powayegg
Stove hood fan/light
My first post since getting my AS. Lots of great suggestions and ideas. Have a 2013 25RB and absolutely love it. Went to Radio Shack and picked up a 5 amp fuse per suggestion on another post about the fan. Never would have thought to take the filter screen off and lock for a fuse. Saved me a trip to the dealer and that is always good
Powayegg is offline   Reply With Quote
Old 08-17-2013, 02:46 PM   #26
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy!
When it blows next time, increase the tension on fuse to ensure good contact...
Welcome aboard! Show some pix if your AS(Air Stream)!
Peace
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-29-2014, 05:30 PM   #27
DMT
DMT's Avatar
Range hood dead - fuses OK - no clue
We have had several blown fuse incidents which only happened when both the range hood fan and lights were used simultaneously. This was becoming an annoyance and an inconvenience so we elected to replace both halogen bulbs with LED units. They use much less current and generate far less heat. So far so good - no more blown fuse issues. I liked it so much I changed the bulb above the outside door to an LED strip. Ordered both from LED4RV.
Old 07-21-2016, 12:38 AM   #28
benjisgal's Avatar
2010 23' FB Flying Cloud
Fayetteville , Georgia
Images: 16
Range hood
When fuse blows, do you lose both the fan and lights. Trying to figure out if I need a fuse or the motor for the Baraldi range hood vent.
Benjisgal
WBCCI #1122
Top of Georgia Unit #52
“I don’t want to get to the end of my life and find that I lived just the length of it; I want to have lived the width of it as well.”
---Diane Ackerman (Author, poet, essayist, naturalist)
benjisgal is offline   Reply With Quote
Old 07-21-2016, 09:31 AM   #29
DMT
DMT's Avatar
Both
Old 10-09-2017, 07:12 PM   #30
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Haines , Oregon
Well, our range hood fuse finally died. It lasted 5 years before finally biting the dust.
The fun began when I tried to find a replacement fuse. The local Autoparts stores had nothing that was the physical size, but our NAPA store said to check out the local builders supply. It turns out they're a Traeger BBQ dealer, and Traeger uses that size fuse in a 5 ampere rating. I believe there was a thread that quoted AS as recommending using the larger rating. Hope I don't go up in smoke.
So, if you can't find the fuse look for a Traeger dealer.
Old 07-05-2018, 05:17 PM   #31
DMT
DMT's Avatar
After changing out the halogen bulbs to LED I have gone three years and counting on the same fuse without incident. In my opinion the problem was the relatively high current draw when both the halogen range hood lights and the range hood fan were used simultaneously.
Old 01-03-2019, 09:47 PM   #32
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Yep, the 5 amp fuse works fine and you can find it on amazon.... think I paid $5 for 10 of them. If I mention them at a rally, and I usually give one away. Someone always has a blown fuse that is inobtanium.
Thermostat dead? vegburner Furnaces, Heaters, Fireplaces & Air Conditioning 7 02-11-2012 06:50 PM
How much would you pay for a dead silent (or close) generator Nightwatch Generators & Solar Power 65 06-22-2011 09:14 AM
Load range D will work. Is E better? blickcd Tires 5 04-10-2011 06:53 AM
Range hood exhaust fan KyMoonshine Roof Vents, Skylights & Fans 3 02-20-2011 06:28 AM
TowMaster range E trailer tire tvanwave Tires 8 01-14-2011 04:50 PM
