Old 07-21-2016, 10:31 AM   #29
DMT
DMT's Avatar
2011 27 FB International
East Coast , Newfoundland
Both
[AIR# 55762 TAC# NFL-1
DMT is offline   Reply With Quote
Old 10-09-2017, 08:12 PM   #30
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Well, our range hood fuse finally died. It lasted 5 years before finally biting the dust.
The fun began when I tried to find a replacement fuse. The local Autoparts stores had nothing that was the physical size, but our NAPA store said to check out the local builders supply. It turns out they're a Traeger BBQ dealer, and Traeger uses that size fuse in a 5 ampere rating. I believe there was a thread that quoted AS as recommending using the larger rating. Hope I don't go up in smoke.
So, if you can't find the fuse look for a Traeger dealer.
Old 07-05-2018, 06:17 PM   #31
DMT
DMT's Avatar
After changing out the halogen bulbs to LED I have gone three years and counting on the same fuse without incident. In my opinion the problem was the relatively high current draw when both the halogen range hood lights and the range hood fan were used simultaneously.
Old 01-03-2019, 10:47 PM   #32
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Yep, the 5 amp fuse works fine and you can find it on amazon.... think I paid $5 for 10 of them. If I mention them at a rally, and I usually give one away. Someone always has a blown fuse that is inobtanium.
Thermostat dead? vegburner Furnaces, Heaters, Fireplaces & Air Conditioning 7 02-11-2012 07:50 PM
How much would you pay for a dead silent (or close) generator Nightwatch Generators & Solar Power 65 06-22-2011 10:14 AM
Load range D will work. Is E better? blickcd Tires 5 04-10-2011 07:53 AM
Range hood exhaust fan KyMoonshine Roof Vents, Skylights & Fans 3 02-20-2011 07:28 AM
TowMaster range E trailer tire tvanwave Tires 8 01-14-2011 05:50 PM
