Old 07-03-2012, 03:57 PM   #15
DMT
DMT's Avatar
2011 27 FB International
East Coast , Newfoundland
Sorry, should have read Motozen not Motown. The word suggestor on this phone is more of a nuisance than a help.
[AIR# 55762 TAC# NFL-1
DMT is offline   Reply With Quote
Old 07-03-2012, 06:20 PM   #16
drew05's Avatar
2011 25' FB Flying Cloud
Peculiar , Missouri
Motozen, I believe the 2012 hoods are the same as 2011. There is a fuse holder in the hood itself. I have a copy of the Service literature and will try to attach it here.
Drew
drew05 is offline   Reply With Quote
Old 07-03-2012, 06:24 PM   #17
drew05's Avatar
Peculiar , Missouri
The hoods are attractive, but I think the switch assy is cheap. If you press on it too hard you can push it into the hood. It's an easy fix, but still feels cheap. Luckily we keep a couple of long wooden cooking utensils onboard. After removing the filter, you have a lot of room to all of the components.
Good Luck
Old 07-04-2012, 06:52 PM   #18
DMT
DMT's Avatar
Bought a replacement fuse at radio shack and it is working again. The fuse was a 3.15 amp 250 volt, and it is not mentioned in either the Baraldi range hood manual or the Airstream parts manual.
Old 07-04-2012, 08:45 PM   #19
drew05's Avatar
Peculiar , Missouri
DMT, was it a standard or mini fuse?
Old 07-05-2012, 07:14 AM   #20
DMT
DMT's Avatar
Not sure what standard would be, but this is a glass fuse, slow burn type. The writing on it uses some kind of proprietary Italian font size that is impossible to see with the human eye. My wife could see it but I would need a scanning electron microscope.
Old 07-05-2012, 07:33 AM   #21
drew05's Avatar
Peculiar , Missouri
Old 07-08-2012, 03:25 AM   #22
DMT
DMT's Avatar
Fuse blew again. Something's up.
Old 07-16-2012, 10:31 PM   #23
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Check the wiring back into the wall. They rough cut the inside skin and do not protect the wires - chaffing will cause a short when towing. That's what I found with my heater when it kept blowing fuses. How much can a piece of rubber edge guard cost?
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 07-17-2012, 03:16 AM   #24
DMT
DMT's Avatar
Add that to Gene's suggestion thread.
Old 08-17-2013, 02:58 PM   #25
Powayegg's Avatar
2013 25' Flying Cloud
Livingston , Texas
Send a message via Skype™ to Powayegg
Stove hood fan/light
My first post since getting my AS. Lots of great suggestions and ideas. Have a 2013 25RB and absolutely love it. Went to Radio Shack and picked up a 5 amp fuse per suggestion on another post about the fan. Never would have thought to take the filter screen off and lock for a fuse. Saved me a trip to the dealer and that is always good
Powayegg is offline   Reply With Quote
Old 08-17-2013, 03:46 PM   #26
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy!
When it blows next time, increase the tension on fuse to ensure good contact...
Welcome aboard! Show some pix if your AS(Air Stream)!
Peace
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-29-2014, 06:30 PM   #27
DMT
DMT's Avatar
Range hood dead - fuses OK - no clue
We have had several blown fuse incidents which only happened when both the range hood fan and lights were used simultaneously. This was becoming an annoyance and an inconvenience so we elected to replace both halogen bulbs with LED units. They use much less current and generate far less heat. So far so good - no more blown fuse issues. I liked it so much I changed the bulb above the outside door to an LED strip. Ordered both from LED4RV.
Old 07-21-2016, 01:38 AM   #28
benjisgal's Avatar
2010 23' FB Flying Cloud
Fayetteville , Georgia
Images: 16
Range hood
When fuse blows, do you lose both the fan and lights. Trying to figure out if I need a fuse or the motor for the Baraldi range hood vent.
Benjisgal
WBCCI #1122
Top of Georgia Unit #52
I dont want to get to the end of my life and find that I lived just the length of it; I want to have lived the width of it as well.
---Diane Ackerman (Author, poet, essayist, naturalist)
benjisgal is offline   Reply With Quote
Thermostat dead? vegburner Furnaces, Heaters, Fireplaces & Air Conditioning 7 02-11-2012 07:50 PM
How much would you pay for a dead silent (or close) generator Nightwatch Generators & Solar Power 65 06-22-2011 10:14 AM
Load range D will work. Is E better? blickcd Tires 5 04-10-2011 07:53 AM
Range hood exhaust fan KyMoonshine Roof Vents, Skylights & Fans 3 02-20-2011 07:28 AM
TowMaster range E trailer tire tvanwave Tires 8 01-14-2011 05:50 PM
