Old 06-11-2015, 04:25 AM   #1
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Propane tube to burner on stove
A year or two ago, we found the front center burner on our stove wasn't lighting. When I investigated, I found that the gas tube had fallen out. I put it back together, but it continues to fall out every time we hit the road. The problem is that I can't figure out how the spring clip holds it in place. Would someone please take a picture of theirs and post it here so I can see how it should look? I would really appreciate it.
This is the stove in our '95, but I suspect this design was used for many years.
This picture has the tube in place but I just hung the spring clip on the tube in the picture so you could see what I mean. Thanks.
Name:	ImageUploadedByAirstream Forums1434018247.987552.jpg
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 06-11-2015, 08:37 AM   #2
Zil
egg harbor city , South Jersey
It must fasten as the other two are clipped. From one tube under/over the center to the second tube. I bet you have one clip missing as the clip appears to go from one tube to the other, I would guess three clips with two hooks over each tube.
Zil is offline   Reply With Quote
stove burner Lucy98 Stoves, Ovens & Microwaves 0 04-25-2011 03:29 PM
Stove-top burner tubes wacnstac Stoves, Ovens & Microwaves 17 06-03-2010 06:35 AM
Two Burner Stove Foiled Again Full-Timing 2 11-17-2007 10:32 PM
Help ! In need of a burner tube. C Johnson Stoves, Ovens & Microwaves 10 10-25-2006 10:32 PM
