Old 07-04-2019, 02:01 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Pilot lites, but nothing else
Oven pilot can be lit but after itís turned to anything else...nothing.
I try lighting the burner manually but again, nothing.
It canít be thermocouple right, since the pilot stays lit ?
Dan
Dan S is offline   Reply With Quote
Old 07-04-2019, 04:37 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Based on pilot staying on, I bet on the gas valve. I presume you are operating it correctly, i.e. pushing in on the knob and rotating it to the ON position and holding it for a few seconds before releasing it, or whatever your instructions say.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-04-2019, 06:24 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If this is the original stove I don't think there is a thermocouple. When was it last used? Another possiblity is a bad regulator. Will the fridge and hot water heater fire up?
Old 07-05-2019, 04:30 AM   #4
1973 Argosy 22
Gold Hill , North Carolina
I have a 73 model Argosy with the original stove. A couple years ago my oven developed the same problem as yours. The pilot would light, but the burner would not come on when advancing the temp control knob. The control valve is operated by a mercury type sensor that the pilot heats. I have not been able to find a replacement sensor for mine. I have tried to finding a replacement, but thus far no success. If anyone knows where one can be found, I would like to know.
n89217 is offline   Reply With Quote
Old 07-05-2019, 05:48 AM   #5
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
My Overlander's '67 Magic Chef operates differently than modern ovens. Lighting the pilot light does not involve pushing & holding the knob - I just turn the knob to pilot, wait for the gas to run through, and light it.
The heat from that warms up a thermocouple hooked to the thermostat. When the thermostat calls for heat and the thermocouple is warm enough, it supplies gas to a secondary pilot immediately beside the primary pilot. This larger pilot light warms a different thermocouple hooked to a separate gas valve. When that thermocouple is warm enough, the gas valve opens and supplies gas to the main burner.
On occasion, the secondary thermocouple vibrates out of position has to be re-aligned or the main burner never lights.
Tom
Old 07-05-2019, 06:25 AM   #6
fluxcap's Avatar
1977 Argosy Minuet 6.0 Metre
Newnan , Georgia
Ditto what Tom said. When we got our 77, we had the same issue. I loosened the set screw for the thermocouple and tried moving it a couple of times and found the sweet spot. Itís been four years and I havenít had to adjust it again so far.
fluxcap is offline   Reply With Quote
Old 07-05-2019, 11:39 AM   #7
fwjumper's Avatar
1998 34' Limited
Lawrenceville , Georgia
After lighting the pilot, ours takes a while for the burner to light, especially the first time. Are you waiting long enough? Maybe a minute or two?
fwjumper is offline   Reply With Quote
Nothing Ventured, Nothing Gained chdeatley Airstream Classifieds 1 11-02-2017 06:37 PM
Outlets work but nothing else never have had a battery hooked up NoFxJohnson General Repair Forum 25 07-16-2017 11:04 AM
Nothing but a 14x25 hole in the roof nmeyer Roof Vents, Skylights & Fans 10 04-20-2015 03:39 PM
brake lites and backup lites goldie Lights - Interior & Exterior 1 03-09-2010 07:47 AM
Nothing getting through the Pilot jet wander'n Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-29-2009 10:20 PM
