Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 02-19-2006, 11:54 AM   #1
Rosie the Riveted
ironfem200's Avatar
Profile:  1955 18' Wanderer
Oakland , California
Paint stovetop with high temp paint?
Looosy's stovetop is rusty and in need of help. My question is: does high temp paint off-gas toxic fumes when heated? My trailer is pretty small and I use the burner/inverted clay pot method for heating the place.
Any thoughts?
thanks!
Anne-Marie
ironfem200 is offline   Reply With Quote
Old 02-19-2006, 03:18 PM   #2
moderator
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
Do a forums search for powder coat. Several folks have removed the top and had it powdercoated or - if it's stainless, polished out and buffed to shine.
77 Argosy Minuet, 6 metre | 77 Argosy 24, Rear door
AIR # 3181 | WBCCI # 5575
Bullies thrive where leadership fails
Janet is offline   Reply With Quote
Old 02-19-2006, 04:27 PM   #3
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
Anne-Marie,
We painted our with hi temp silver. As long as it's open when the burner is on it does not get hot on ours.
If I may...heating with the stove is a really bad idea, very dangerous. Is there something wrong with your furnace?
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 02-19-2006, 04:38 PM   #4
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
I put BBQ paint on the burner bases. Gloss black, of course, and have had no problems. The spray can says it is good to 750 degrees.
(No Longer at Inland RV)
Old 02-19-2006, 04:47 PM   #5
Rosie the Riveted
ironfem200's Avatar
thanks for the input--high temp paint
hi all. Indeed, there is a problem with the wall furnace, hence the stove heating method.
Blue paint uwe Clearcoat, Exterior Paint & Trim 32 11-20-2009 04:05 PM
Paint Repair Primer Howard Lefkowitz Clearcoat, Exterior Paint & Trim 2 08-25-2002 12:56 PM
Paint Removal from side of A/S Lexxy Clearcoat, Exterior Paint & Trim 2 08-19-2002 08:03 AM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 06:39 PM
Help...re Paint GOOFUP Cat Clearcoat, Exterior Paint & Trim 3 04-18-2002 09:14 PM
