Old 09-16-2002, 10:03 PM   #1
Airstream Driver
PeterH-Airstreamer's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 51
Oven Thermostat
I have a Magic Chef oven (upper). The thermostat does not work properly. There is the heat sensor which has a wire that runs to the oven temp knob.
Has anyone ever messed with the knob, is it repairable, are there replacements?
1992 350LE Classic Motorhome
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 09-16-2002, 11:29 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I have the same question on the oven for our '64 GlobeTrotter...just haven't gotten around to posting it.
Thanks Peter...now I guess we just sit back & wait, huh?!
Shari
Old 09-17-2002, 12:14 AM   #3
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Oven?
Oven? I thought everyone cooked outside using a "FIRE RING"~!~ <smiles>
53flyingcloud is offline   Reply With Quote
Old 09-17-2002, 12:51 AM   #4
InsideOut's Avatar
1956 22' Safari
Images: 108
Not in Colorado with our drought!!!
NO Campfires allowed ~ at least this year!
Shari
Old 09-17-2002, 07:17 AM   #5
Airstream Driver
1994 30' Excella
Images: 51
Shari
Shari,
we already did sit back and wait and saw the results.
I have a feeling they could be many of us, some have yet to find out.
AIR #13
Old 09-18-2002, 04:04 PM   #6
I'm in the same boat. No fire down below. Rangetop works fine. What's the best source for a replacement oven/rangetop?
NSMITH is offline   Reply With Quote
Old 09-18-2002, 06:38 PM   #7
Some oven parts are still available, but it depends on the Magic Chef model.
Four burner ranges with ovens are no longer available. For some reason, only 3 burner ranges with ovens have been it, for the last couple of years.
Cut out dimensions are required before any replacement can be researched.
inlandrv.com
airstreamparts.com
Old 09-19-2002, 07:31 AM   #8
Andy:
Ballpark - what do the prices tend to run on RV replacement range/ovens for A/S? This is 84 Excella 31' with 4-burner range/oven as one unit. I've talked to parts supplier for Magic Chef, who is no longer around. My replacement parts will run me approx $215. May not be worth repairing if I can get replacement at right price.
Neal
Old 09-19-2002, 09:33 AM   #9
Sticker prices on a Magic Chef 16 inch drop in range in Bisque color is $390.00, and in Black it's $450.00.
A 22 inch drop in, in Bisque is $515.00 and Black is $500.00.
These are round "BALL PARK" numbers, as you asked for.
inlandrv.com
airstreamparts.com
Old 09-19-2002, 11:17 AM   #10
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
My wife and I have had some trouble with our washing machine, and I decided to repair the problem myself. While hunting down parts I went to several appliance parts places around town. It seems like there are many generic type parts used in older appliances, at least that's what I overheard from the guys that were behind the counter. " Oh yeah, we got one that will work".
Might be worth taking a look at, so long that it is a recommendet replacement part and does not cause a safety issue. As always, use common sense and put safety first.
Uwe
www.area63productions.com
Old 09-20-2002, 09:29 AM   #11
LOST , Hawaii
Stove prices
Campers choice Search on 'Magic Chef'
22" $300 16" $240.
John
74Argosy24MH is offline   Reply With Quote
Old 10-26-2002, 12:21 PM   #12
1975 31' Sovereign
Eau Claire , Wisconsin
thermostat for magic chef
If I can pick up this thread again; I too am in need of a thermostat for the oven portion of my cooking outfit. It is a four burner Magic Chef which I assume it is original. The range part works fine, the oven is like a blast furnace that you can't control. It's either on or off. I am assuming I need to replace the thermostat. Has anyone who took part in this discussion earlier come up with a source for such parts for older Magic Chef's?
Brouck
bhsl8 is offline   Reply With Quote
Old 10-26-2002, 07:19 PM   #13
InsideOut's Avatar
1956 22' Safari
Images: 108
Brouck ~
You described our problem to a "T"-stat The only way I've controlled the temp so far was to turn the oven on & off every couple of minutes...it's worked the two times I made peach cobbler & 1 time I baked cookies this summer
I don't want to replace our oven...just fix it. But, that's one of the things on my list of "things to do" for this winter so it's "perfect" next year.
When we were fine-tuning on our stove top this spring, I found a source for replacement parts. I've been meaning to look them up again for this but haven't done it yet...I'll post when I do or if I find another solution...please do the same if you come up with something.
Shari
Old 10-26-2002, 09:00 PM   #14
Thermostat sources
Nearly every city of any size has an appliance parts store - check the yellow pages. On older models, the brand and model number may no longer be referenced in their books. However, if you can get the name and number off the thermostat itself there is every likelyhood they can come up with a replacement.
I could mention that I just gave away a four burner oven/range because it took up too much space, but that might distress some of you, so I will not mention it.
Mark
Old 10-26-2002, 09:27 PM   #15
InsideOut's Avatar
1956 22' Safari
Images: 108
Thanks for not mentioning it Mark
Shari
Old 10-26-2002, 09:47 PM   #16
Airstream Driver
1994 30' Excella
Images: 51
I went to a local appliance store and was told that the knob/thermostat is one complete assembly and only available thru a RV specific appliance place.
They also had no reference or cross reference for the oven serial number.
AIR #13
Old 10-26-2002, 11:36 PM   #17
InsideOut's Avatar
1956 22' Safari
Images: 108
Peter ~
I wonder if that's the case with my older one too? Hmmm...now my curiousity is peaked, I may have to find time to fit this "quest" in sooner rather than later ~
Shari
Old 10-27-2002, 01:43 PM   #18
1975 31' Sovereign
Thanks y'all. I too haved baked up a couple of delights with "manual control". The choclate chip cookies were crunchy on the outside and soft in the middle... not bad with milk! The biscuits on the other hand were way to dry, not even the gravy helped. There are some numbers on the part itself but difficult to make out.I will be taking it to an appliance store to see if they can decipher. I am 100 miles from civilization enough to find "parts heaven". We must take the buckboard to town for provisions every month!If any one does come up with a source I'd appreciate it.
Brouck
Old 12-28-2002, 08:10 PM   #19
Forrest's Avatar
1986 32' Excella
Aurora , Colorado
Images: 21
Unhappy Harper Thermostat
I have a 1966 Magic Chef, 4 burner, also. The stove top works fine, but the thermostat doesn't control the oven. It lights, but just like it's been said in some of the postings it has to be manually controlled. The owners manual indicates that under the control knob there is a heater pilot adjusting screw (green) and a constant pilot adjusting screw (red). When I checked for these I noticed that the heater pilot adjusting screw was still there, but the constant pilot screw (red) was missing. I haven't been able to find a suitable replacement part yet -- any suggestions???? Might this be all there is to the problem???
Forrest is offline   Reply With Quote
Old 12-28-2002, 08:35 PM   #20
Magic Chef
Hart Enterprises @ 1.800.782.2455 is who Magic Chef told me to call to get replacement parts for my stove/oven.
I needed a nut & ferrule for my oven pilot light and they had it stock @ $1.40 plus $5.70 for S&H.
John
John is offline   Reply With Quote
Thermocouple and Thermostat....HIGHWAY ROBBERY!! Alan and Mardel Water Heaters, Filters & Pumps 2 12-23-2003 03:41 PM
Oven in the wall garry Stoves, Ovens & Microwaves 2 10-11-2003 07:27 PM
1971 safari oven altastars Stoves, Ovens & Microwaves 1 09-04-2003 08:42 AM
1971 safari oven altastars Stoves, Ovens & Microwaves 5 09-03-2003 07:07 PM
No Buns in this Oven NSMITH Stoves, Ovens & Microwaves 2 06-03-2002 08:54 PM
