Old 06-07-2015, 03:02 PM   #1
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Oven Temperature Calibration
Anyone know if there is a calibration or an adjustment that can be made so the actual oven temperature is close to the knob setting? On my Atwood range, you have to set the knob to 400 to get the oven temperature up to 350 (as measured by an oven thermometer). It gets worse from there.
Randy
Randy and Pat Godfrey
Region 3 1st VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 06-07-2015, 03:41 PM   #2
Piggy Bank's Avatar
2017 25' Flying Cloud
2015 22' FB Sport
Kansas City , Missouri
I don't know if there is a calibration to do. But I will say that my home oven is about as bad.
Conspiracy theory is that is an energy star thing. Manufacturer's "tolerance" are often very wide for these readings. (Which was the case with my home oven).
You may need to just do a "spinal tap" and over shoot the setting to get the actual temperature to be what is needed. (go to 11 when you really need 10. Look on youtube if you don't get the reference to the movie This Is Spinal Tap).
Also realize that being in a high altitude may impact the heat output due to oxygen levels as well.
A $5 oven temperature thermometer will help to keep things where they need to be. Also realize that many new home ovens "beep" that they are preheated after a set amount of preheat time; having no correlation at all to the interior oven temperature. Again, measure it with an oven thermometer for best results.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 06-07-2015, 04:03 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
That knob is your calibration. I have never had a gas range that the actual temp matched the knob. Trial and error will tell you where to set the temp for your use.
MICHAEL
Old 06-07-2015, 04:05 PM   #4
dznf0g's Avatar
Oswego , Illinois
Mine's off too. Use a digital oven thermometer
-Rich-
MicroPulse Calibration For Battery jeff4506 Batteries, Univolts, Converters & Inverters 9 03-06-2017 06:41 PM
Micro Pulse Tank monitor calibration Silvertwinkie Plumbing - Systems & Fixtures 98 11-03-2014 02:09 PM
Air Gauge Calibration tvanwave Tires 17 09-17-2010 06:39 AM
Duo-Therm Thermostat out of calibration? silverback Furnaces, Heaters, Fireplaces & Air Conditioning 2 05-03-2009 06:55 AM
oven temperature ga501 Stoves, Ovens & Microwaves 1 01-24-2006 06:31 PM
