Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 01-24-2006, 04:30 PM   #1
ga501's Avatar
Profile:  1956 26' Crusier Overlander
douglasville , Georgia
oven temperature
Does anyone how hot it gets around and behind an oven?? Having removed mine to repair the floor underneath, I found the 3/8 copper line barely
crimped. The stove works seems to work ok but was going to replace the
line before reinstalling the stove. Sholud I stay with copper (flared fittings,
of course) or do they make a flexible low pressure line that would work??
I've seen rubber lp lines advertised, but not sure they'd work without
melting. Flex lines are available for residential/commercial applications,
just not sure about the rv industry!!
Steve
ga501 is offline   Reply With Quote
Old 01-24-2006, 06:31 PM   #2
norbert's Avatar
Profile:  1993 30' Excella
chicagoland , state of confusion+north of cheddar curtain
Images: 24
[quote=ga501]Does anyone how hot it gets around and behind an oven?? Having removed mine to repair the floor underneath, I found the 3/8 copper line barely
just not sure about the rv industry!![/quote
IMHO, you sholud stay with copper.....
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
oven out 74Sovereign Stoves, Ovens & Microwaves 19 12-10-2003 07:03 AM
Oven Thermostat PeterH-79MH Stoves, Ovens & Microwaves 33 02-20-2003 10:39 AM
Antenna & Oven Difficulties Tamara General Repair Forum 13 07-30-2002 05:33 PM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 04:52 AM
No Buns in this Oven NSMITH Stoves, Ovens & Microwaves 2 06-03-2002 08:54 PM
