Old 09-05-2014, 01:55 PM   #15
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Your first post suggested that the thermostat was working, because the burner went off when the oven reached the set temperature. Suggest you check everything you took apart when you blew the obstruction out of the pilot light. Something may have remained disconnected, or might have moved out of its correct location.
I know when I work on something, I often cause something while I'm trying to fix something else. I'm just clumsy, I guess.
Good luck.
Old 12-03-2014, 02:42 AM   #16
Natty Lite's Avatar
Mandeville , Alabama
Jason,
This is the same problem I'm having with my oven! Let me know how it goes, I need to get mine working as well!
David Eddy
Natty Lite is offline   Reply With Quote
Suburban NT30: Pilot Light Won't Light 2xS Furnaces, Heaters, Fireplaces & Air Conditioning 31 03-03-2010 09:26 AM
Water Heater Pilot Won't Light SteveH Water Heaters, Filters & Pumps 11 10-20-2007 07:50 AM
Pilot light won't stay lit abridges01 Refrigerators 5 09-25-2006 12:01 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 05:24 PM
Pilot Light won't stay lit Mike Callaha Water Heaters, Filters & Pumps 15 03-26-2005 01:56 PM
