Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 06-24-2009, 11:33 AM   #1
blickcd's Avatar
Profile:  1979 31' Sovereign
Batavia , Ohio
Oven pilot light problem, '79 Magic Chef
Not sure of the model number of the stove but it is a Magic Chef with 4 burners on top and a conventional gas oven with a glass oven door and 12 volt light inside. It is installed in a '79 Airstream and I assume it is original.
My problem is that whenever I go out for a weekend trip and light the oven pilot, it may or may not go out after about half an hour. It's kind of a random thing. Note that it lights easily enough. Another flakey thing is that sometimes when you turn on the oven for the first time on a trip, the pilot light goes out. If the oven is used once and the pilot light is left burning, it seems to be fine for the rest of that stay.
My guess is that the thermocouple for the pilot light is bad. Are these still available and where is the best source for one? Any advice on if this is a pain of a job to replace and any tips are welcome.
Christopher
blickcd is offline   Reply With Quote
Old 06-24-2009, 10:14 PM   #2
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
Your problem is with the pilot light I believe and not the thermocouple. The thermocouple tells the oven the pilot is lit and it's OK to kick on the gas - which it seems to be doing from your description. The manual I have lists the following reasons for the pilot going out:
Dirty pilot - clean
faulty thermostat
Low gas pressure
air shutter on main burner open/closed - adjust
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 06-25-2009, 10:55 AM   #3
blickcd's Avatar
Batavia , Ohio
Thanks. I'll look into that stuff.
Christopher
Magic Chef Oven Pilot flames/blows out HansenClan LP Gas, Piping, Tanks & Regulators 3 09-22-2008 11:28 PM
Looking for pictures of early 60's Magic Chef oven Pilot assembly volvophile Stoves, Ovens & Microwaves 9 07-04-2007 06:33 PM
Magic Chef Pilot Light Supply Tube fun2bethad Stoves, Ovens & Microwaves 16 03-04-2006 11:03 AM
How to light pilot on Magic Chef? Diesel Pusher Stoves, Ovens & Microwaves 1 07-19-2004 02:27 PM
Magic Chef Oven pilot sammamishsafari Stoves, Ovens & Microwaves 2 08-22-2003 09:17 PM
