Yes, you all thought we were finished fixing things in this stream but NO! ...The exhaust (sp) vent over the stove has never worked...what are some ways we can check.? Fuses? wires? It has a open/close cover and a metal filter that comes in and out...also there is the push on/off button on the right side underneath...what should I look for?
__________________ ...Lots of people want to ride with you in the Limo, But what you want is someone who will take the bus with you when the Limo breaks down....http://smileys.smileycentral.com/cat/23/23_30_126.gif
The original cover had a handle on the side. When you moved that handle, to open the vent cover, a microswitch turned the fan motor on.
The fan motor is the same as in the original ceiling fans.
I will send in a picture tomorrow in the daytime of everything the camera will pick up...thanks Andy.
Andy, would there be a microswitch on a unit with a push button? That seems strange to me.
I would always check for voltage at the fuse before anything else, then go to the switch,then to the fixture itself, depending on what you find at the switch. If there are both a push button, and a handle controlled switch, the push button would have power first. When the button is pushed it would provide power to the handle switch. With both the push button and the handle switches checking out okay, I would go to the fan motor and see if power is reaching it.
It might be a simple problem. My fan wouldn't work until I turned it by hand a few revolutions. Once it started, I let it run for about ten minutes, and it worked out the problem on its own. I think it was just a matter of corrosion on the motor stator that self-cleaned with a little run time. Now if I could just get rid of that squeak!
My unit has the lever and switch. The lever is attached to a cable that opens a flap door on the side of the trailer that covers the exhaust motor. I believe that this arrangement was first introduced in 1974 when the control panel was moved from the front wall to the over head compartment. The earlier units had a scoop type vent with no moving parts. The push button or switch makes sense to me for these earlier units.
I would meter out the circuit to make sure that 12 volts is getting to the fan motor and go from there.
Well here's three pictures of it for this morning...I can take the filter out too (I think)!...there is one (1) push button on the right. And a vent cover which swings out...there isn't a microswitch but if there is one, this will be a first for me.
Then I went outside and openned the compartment and took these shots...that one fuse with (aluminum) on it is an emergency rig we had to do last winter...are there special no#s for fuses (universal)?...we also have the original owners manual onhand if you want to direct us to the correct part of it...
Good luck, Rich
Your switch deal is OK.
The comutator on the motor shaft is rarely a problem, but could be.
Your motor problem is more likely due to dry bearings or brass sleeves at each end of the motor.
We'll do our research and will report back this PM.
Ok, we took out the six screws holding it. Pulled it downward and took this picture after we took a vacuum and sucked out the dirt that has been there for some time...all the wires are connected accept for the one you see me holding...Angel says he took his fingers and rotated the fan itself and it was real tight or a little hard to turn...what can you guys see...and is there access to the fan for oiling (wd40) from the outside.?
WD-40 is not a lubricant.
Oil should be used.
Usually, but not always, a tight or locked motor shaft suggests that the motor armature has become seized due to lack of a lube.
When that happens usually the bearing gets chewed up a little. If oiling the bearings frees up the shaft, your in good shape, however, when the motor gets hot, it may squeal.
Ok then, can it be oiled from the outside, do you think? We have the 3-1 oil on hand and what do we oil?
If we approach it from the outside we took notice that the rivets will have to be drilled out gently (there's about six-eight of them) then un screw the net cage and then un screw the fan from the outside to get it out...we are figuring that it probably DID go out...there was a disconnected wire if you see that certain picture (white) (wire) ...And if we replace it- the next question is Inland RV going to have a replacement or are there alternative fans? We thought about it all for a bit and came to the conclusion that ripping it out and causeing havoc in the cooking area, we would 'sneak' up on it instead and do the research....
