Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 01-07-2017, 01:31 PM   #1
2005 25' Classic
SomeWhereIn , South Carolina
Oven not working...
Anyone know why the oven in a 2005 25ft Classic won't work? I can't get the pilot to light, but on the other hand, the burners on the stovetop are working perfectly.
Thanks.
smokinjoe is offline   Reply With Quote
Old 01-07-2017, 02:56 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Probably a bad thermo couple. An easy fix. The thermo couple is the thin rod that gets heated by the pilot flame. The pilot will not stay lit is if the thermo couple is bad.
2019 Ford Expedition Platinum
Old 01-07-2017, 04:55 PM   #3
Sag Harbor , New York
smokinjoe, can you light the pilot at all? Usually there is a special instruction for lighting the pilot light [to override the thermocouple for 30 seconds or so], so you might want to check the manual for the oven which should have come with your AS paperwork.
If you are unable to light the pilot, following the mfg. instructions, then the gas valve may be bad IMO.
If the pilot lights and then goes out when you exit the short-term override, then yes the thermocouple may be bad, as W&S just said.
Good luck!
Peter
PS -- What mfg. gas oven model do you have?
Old 01-07-2017, 06:34 PM   #4
brokeboater's Avatar
2013 25' Flying Cloud
Crystal River , Florida
Possibility of a broken pilot light line. Check to make sure the small supply line to the pilot light, aluminum in my current rig, is intact. Not unusual for one to be broken. If it's broken the gas will leak out before reaching the pilot light.
brokeboater is offline   Reply With Quote
Old 01-07-2017, 07:27 PM   #5
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Have you used it previously without problem or is the trailer new to you?
The oven pilot light in our 2005 Classic is a bit fiddly to light but it will light. We rarely use the oven.
I use a butane gas lighter to light the pilot. When the pilot first lights, you need to hold the gas knob pushed in for 30-60 sec. to let it heat the thermocouple - it should stay lit at that point when you release the knob, and the main burner should then light up.
If it won't stay on when you release the gas control knob, there is likely a problem with the thermocouple.
If it won't light at all even with the valve knob pushed in, then probably an issue with the gas line or control valve. (Assuming your other gas appliances are working as they should.)
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-08-2017, 08:16 AM   #6
2005 25' Classic
Trailer is new to me. As said, the stovetop works, but the oven does not. I'll try some of the suggestions given here. Thanks!
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 5 01-06-2020 11:25 AM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
Dometic heater zone 2 not working on furnace, not hot on HP sfgirl General Repair Forum 13 11-06-2015 01:21 PM
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 09:15 PM
Oven not working fwiz General Motorhome Topics 1 09-16-2005 12:21 PM
