Oven Door Tension
Our 2016 Flying Cloud, with the Atwood stove, works well with the exception while traveling. We have found on several occasions that when we stop and get into the trailer, that the over door is open. We don't leave any pots/pans, or baking sheets inside. Our 2006 Safari oven door never had this problem. While at Airstream for warrantee work, the tech checked the oven door and stated that he looked at several other brand new AS's and that they had the same tension on their doors. Looking to see if anyone else has noticed this problem and if so, how you resolved it. I've been look at a couple 10 to 20 Lb magnets, one on each top outside corners to assist in keeping the door closed. I have no idea if the heat from the oven will impact the reliability of the magnets.
