Old 03-19-2016, 08:49 PM   #1
2008 27' International FB
1999 19' "B" Van Airstream 190
Marietta , Georgia
Oven door doesn't shut tightly
I just noticed today that our oven door doesn't shut tightly. There's a small gap when it's "closed". If I push on it, it closes tightly but won't stay that way unless I hold it. There's nothing in the way that is preventing it from shutting. Is there some type of adjustment I can make to have it close correctly again?
karenjude is offline   Reply With Quote
Old 03-19-2016, 09:24 PM   #2
1998 30' Excella 1000
Livingston , Texas
Check to see if the screws that hold the bottom hinges on have come loose.
Siegmann is offline   Reply With Quote
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
1994 Excella Entry Door Not Fitting Tightly Carroe Doors & Locks 12 12-18-2015 09:16 AM
Need oven automatic shut-off valve for 76 magic chef eliyahu Stoves, Ovens & Microwaves 1 05-17-2015 12:20 AM
Pump doesn't shut off jcain63 Fresh Water Systems 7 09-01-2014 02:59 PM
WBCCI- Doesn't listen or just doesn't care Stream 1529 WBCCI Forum 30 09-29-2008 04:55 AM
