Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 11-24-2007, 09:41 PM   #1
59er's Avatar
Profile:  1959 18' "Footer"
1964 26' Overlander
birmingham , Alabama
Images: 8
Oven burning really rich - all of a sudden?
Our Magic Chef oven ('64) has just started burning really rich (unburnt, black soot on the inside of the door and glass) on this last trip...?
this is our fourth trip out and it has performed perfectly on the previous trips. this is the first trip we've taken where the temps got near or below freezing but I'm not sure if that's a factor or not?
is there an air/fuel mixture adjustment on the oven like there is on the cooktop and water heater?
thanks
Doug
59er is offline   Reply With Quote
Old 11-24-2007, 10:21 PM   #2
Commercial Vendor
Profile:  Corona , California
thanks
Two things to check.
First, make sure the LPG pressure is between 11 and 13 inches of water column pressure. 12 to 12.5 is preferred.
Second, you should find an air adjustment on the burner.
Before ny work is started on any LPG appliance, the pressure "MUST" be correct.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 11-25-2007, 09:57 AM   #3
59er's Avatar
1964 26' Overlander
Images: 8
how is the pressure checked?
Doug
Old 11-25-2007, 10:39 AM   #4
Druupy's Avatar
Profile:  2005 28' Safari
Port Orchard , Washington
Easy quik fix.
turn on one of the burners on the stovetop.
get a glass or cup of warm almost hot water..
go outside and pour the water slowly on the regulator between the propane tanks.
If it clicks semi-loudly once, you are fixed.
Ice inside the regulator.
it happens mostly when air temp is 33-38 and relative humidity is above 60 percent. outside air is where the "HEAT" comes from, that turns liquid propane into gaseous propane. Dew-frost coats the outside of the regulator and works as a really good insulator. Think Igloo.
So if there is not enough "HEAT" inside the regulator, any trace water vapor in the propane, yes there is water vapor in your propane tank, ices the inside of your regulator. Make it no workey.
In a pinch you can use coffee from the thermos to deice the regulator.
But, be aware, the wastefull missuse of coffee is frowned upon.
Druupy is offline   Reply With Quote
Old 11-25-2007, 11:58 AM   #5
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Check for a spiderweb in the main burner jet.
"Not all who are laudering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is online now   Reply With Quote
Old 11-30-2007, 02:54 PM   #6
TomW's Avatar
Profile:  1967 26' Overlander
Huntsville , Alabama
Forrest had a great solution in this thread: HELP!! Furnace frustration!
Tom
Old 11-25-2007, 12:06 PM   #7
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Send a message via AIM to jcanavera
I'd also bet that you have a spider web in the jet which feeds the main burner. It doesn't take much to restrict the air flow. I cleaned out one on a water heater on a rally. The water heater was sooting big time, and the cobweb in the tube was very small.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
Old 11-30-2007, 10:16 AM   #8
59er's Avatar
1964 26' Overlander
Images: 8
got it.
turned out to be the air adjustment on the main burner. looks like it was blocking all of the air.
also adjusted back the secondary pilot light (whose adjuster screw was hidden behind the oven knob and bezel?).... it had a huge flame.
all better now.
thanks.
Doug
Sudden sewer odor?? Help! Phil/Edee Waste Systems, Tanks & Totes 7 10-18-2007 09:30 PM
I am going to be RICH I tell you! thenewkid64 Off Topic Forum 19 12-16-2004 07:38 PM
I'm Rich! swebster Mechanics Corner - Engines, Transmission & More... 30 10-25-2004 07:34 AM
12V System....Sudden Death! Help, please Alan and Mardel Electrical - Systems, Generators, Batteries & Solar 6 12-13-2003 12:04 PM
