Old 10-05-2011, 12:24 PM   #1
KerriO's Avatar
2008 27' International CCD FB
Bay Area , California
No spark from stove burner pilot
I have an Amana three-burner stove that has always had one very fussy burner when it comes to lighting. It finally stopped lighting alltogether yesterday. The gas flow seems fine it just isn't creating a spark anymore when we turn the "light" knob. I'm not sure how to troubleshoot this.
The area around the burner is clean and dry, as is the little piece that sparks.
Is there anything in particular we should be looking at?
KerriO is offline   Reply With Quote
Old 10-05-2011, 12:48 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
They're fiddly and in many ways it's easier to use a handheld lighter.
Check to be sure the burner cap is grounded.
Old 10-05-2011, 01:44 PM   #3
KerriO's Avatar
Yup, might just resort to a lighter as the quicker fix (and only when we need three burners). Luckily, it's not the front one.
How would one go about doing that?
Old 10-05-2011, 02:16 PM   #4
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
You would need an ohmmeter. When you turn the knob, a crystal generates a spark like the coil and spark plug in your car did years ago. It needs a complete circuit from the stove's frame through the igniter then to the spark electrode. The spark jumps the gap and finds its way back to ground through the burner. Check the gap and position of electrode as well as cleanliness of everything. You should see a good spark when turning knob. Gas doesn't need to be on.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 10-05-2011, 02:37 PM   #5
2008 27' Classic FB
Burkburnett , Texas
Ps. Don't get your finger near gap when turning knob. You won't like the feeling!!!
AIR 47751
Old 10-05-2011, 02:40 PM   #6
2008 27' Classic FB
Burkburnett , Texas
If only one burner is problem, it's most likely mispositioned. Compare to other 2 that work and reposition electrode accordingly.
AIR 47751
Old 10-05-2011, 04:38 PM   #7
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
This is probably the right answer....you may just need to bend the electrode slightly with a pair of needle nose pliers (be careful not to break it).
Additionally, lift up the cover and make sure that the wire is connected to the electrode.
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 10-05-2011, 04:45 PM   #8
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Originally Posted by tkowalyk View Post
....>snip<.... Additionally, lift up the cover and make sure that the wire is connected to the electrode.
Ditto that. We had a lighting problem once and one of the wires had come disconnected while traveling... Here's hoping it's somethat this simple...
TB & Greg and Abbey Schnauzer
#3954
Old 01-16-2012, 10:37 PM   #9
KerriO's Avatar
I realized I never got back to this. It was, indeed, a disconnected. wire under the cover.
[[ Captain's Log ]] Our full-time journey in our 27'FB International
Pilot on but burner flame is flat Rob1966 Refrigerators 3 09-26-2011 07:07 AM
3 Burner Magic Chef counter-top stove questions blazeff13 General Appliance Topics 0 08-14-2011 07:00 PM
'69 Safari Majic Chef 4 burner stove sarasafari Stoves, Ovens & Microwaves 1 07-09-2011 10:31 AM
looking for help with Magic chef oven pilot light jayg Stoves, Ovens & Microwaves 2 06-01-2011 04:18 PM
stove burner Lucy98 Stoves, Ovens & Microwaves 0 04-25-2011 03:29 PM
