Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 08-28-2002, 03:16 PM   #1
1985air345
airstreammotorhomes.com
1985air345's Avatar
Profile:  Charleston , West Virginia
New Microwave Suggestions
The old unit died. Anyone replace theirs? Suggestions?
I am thinking about
(1) bolting it down - can most store bought units be screwed down?
and
(2) ventilation. Do I need to worry about grills to cover the open space or just slide it in the space and forget about it?
Fred H.
No Airstream Anymore..
Fred's Airstream Archives - Motorhomes
Fred's Airstream Archives - Trailers
1985air345 is offline   Reply With Quote
Old 08-28-2002, 04:09 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Many of the store microwaves can be "cabinet mounted" but require a kit. The kit will fill in the hole and allow for ventalation as well as secure the unit in place. This may require a more expensive microwave, but save you from having to make brackets.
I would highly reccomend securing any thing down, or at least getting tension rods to hold it in place as you travel(that is how I keep mine from falling on the floor).
No matter what I would give the new unit some breathing room.
Here is a link to a company that makes trim kits
http://www.microtrim.com/microwaves.htm
This site sells sharp brand ovens and has the trim kits too
http://sharp.smartermall.com/searchr...p?search_id=10
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 08-29-2002, 07:31 AM   #3
Jim Clark
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
I installed a microwave in my 68 GT. Fit it nice and tight into the cabinet. I made my own trim kit. I placed it on a sturdy shelf and used a couple of L Brackets to secure it. Bracket screwed to side of cabinet, remove a screw form the microwave cabinet and attached the bracket. I used only existing screws as was somewhat afraid to drill into the cabinet. The unit has rear and side vents, I have a lot of clearance around the unit. I believe yours is a 84. The new units are much smaller so you should have more than enough room for venting.
On venting I have a large muffin fan mounted under my cabinets which pushes air over the Refer coils and up the Refer vent. Helps a lot, wired to run when ever the trailer is on shore power. This also vents the microwave. BTW I have the same setup on my boat except in addition to the brackets I have a copper bar which is place across the front of the unit when uderway, nothing like a microwave flying across a cabin in heavy weather.
My wife works for Macy*s so we purchased a small Sharp Microwave, well under a $100.00. Figured if it lasted a year good enough. I belvie the unit on the boat is also a Sharp, it gets very hard use and has held up fine.
First Weekend Shindig @ Topsail First Weekend in Jan.
Thanks Jim,
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 08-30-2002, 09:49 AM   #4
LKappenman
Finally Retired
Profile:  , Washington
WE purchased a micro/convection and with a small amount of tweeking it works great we measured the opening first then just got on the phone and started calling. We did not have a oven only a micro so this did the trick very well
Dave and Louise
#2852
Finally Retired
LKappenman is offline   Reply With Quote
Thinking about replacing oven with microwave Stefrobrts Stoves, Ovens & Microwaves 36 01-15-2006 11:02 AM
Installing a microwave in 1976 Overlander? tin can luv Interior Restoration Forum 8 01-31-2004 09:09 PM
microwave compared to a convection microwave. Happycampers Airstream Motorhome Forums 0 10-21-2003 10:41 PM
microwave in a 66 safari? kc airstreamer Stoves, Ovens & Microwaves 4 09-15-2003 09:58 AM
Suggestions on new tow vehicle Diana Langley Tow Vehicles 3 07-08-2003 08:31 AM
