Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 08-28-2002, 02:16 PM   #1
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
New Microwave Suggestions
The old unit died. Anyone replace theirs? Suggestions?
I am thinking about
(1) bolting it down - can most store bought units be screwed down?
and
(2) ventilation. Do I need to worry about grills to cover the open space or just slide it in the space and forget about it?
ViewRVs is offline   Reply With Quote
Old 08-28-2002, 03:09 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Lutz , Florida
Images: 21
Send a message via AIM to thenewkid64 Send a message via Yahoo to thenewkid64
Many of the store microwaves can be "cabinet mounted" but require a kit. The kit will fill in the hole and allow for ventalation as well as secure the unit in place. This may require a more expensive microwave, but save you from having to make brackets.
I would highly reccomend securing any thing down, or at least getting tension rods to hold it in place as you travel(that is how I keep mine from falling on the floor).
No matter what I would give the new unit some breathing room.
Here is a link to a company that makes trim kits
http://www.microtrim.com/microwaves.htm
This site sells sharp brand ovens and has the trim kits too
http://sharp.smartermall.com/searchr...p?search_id=10
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-29-2002, 06:31 AM   #3
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
I installed a microwave in my 68 GT. Fit it nice and tight into the cabinet. I made my own trim kit. I placed it on a sturdy shelf and used a couple of L Brackets to secure it. Bracket screwed to side of cabinet, remove a screw form the microwave cabinet and attached the bracket. I used only existing screws as was somewhat afraid to drill into the cabinet. The unit has rear and side vents, I have a lot of clearance around the unit. I believe yours is a 84. The new units are much smaller so you should have more than enough room for venting.
On venting I have a large muffin fan mounted under my cabinets which pushes air over the Refer coils and up the Refer vent. Helps a lot, wired to run when ever the trailer is on shore power. This also vents the microwave. BTW I have the same setup on my boat except in addition to the brackets I have a copper bar which is place across the front of the unit when uderway, nothing like a microwave flying across a cabin in heavy weather.
My wife works for Macy*s so we purchased a small Sharp Microwave, well under a $100.00. Figured if it lasted a year good enough. I belvie the unit on the boat is also a Sharp, it gets very hard use and has held up fine.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 08-30-2002, 08:49 AM   #4
Finally Retired
WE purchased a micro/convection and with a small amount of tweeking it works great we measured the opening first then just got on the phone and started calling. We did not have a oven only a micro so this did the trick very well
Dave and Louise
#2852
Finally Retired
LKappenman is offline   Reply With Quote
Old 09-21-2014, 11:05 AM   #5
RMB
RMB's Avatar
2010 23' International
Saturna , British Columbia
I own a 23' International, 2010. We never used the Dometic micro that often so I was surprised when it conked out a few days ago while trying to reheat some coffee.
Anyway, that's another issue!
I pulled it out and found that it was not some custom built-in cabinet model...just a normal ordinary counter top model. Off to a local shop where I bought a GE stainless 1.2 cu ft microwave 20" wide that would fit the width of the cut out. without sawing or cutting. The depth and height did not exactly match the Dometic dimensions. All I had to do was drill 3 holes on the top of the microwave oven to remount the AS supplied vent panel, and then insert the micro, reattaching the said vent panel. The lower vent pant just slid in and I screwed it back where it belonged.
to the wood cabinet.
The differences in height and depth were accommodated by moving the AS top vent panel upwards an inch or so. The cabinet itself is deep enough to accommodate a horse so no issues there.
That's it.
"I carry what I can, and leave the rest behind" Epicurus
"All that is mine, I carry with me." Cicero
RMB is offline   Reply With Quote
Old 09-21-2014, 12:44 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I was thinking of replacing my microwave with a combo convection microwave. I pulled it out to see what would be involved. Looks like a pretty straight forward swap. Definetly plenty of extra room to work with if I wished to go with a larger unit. I rarely use the oven in my house, same in the trailer. It does make a good space to store pots and pans.
MICHAEL
Microwave compared to a convection microwave. Happycampers Airstream Motorhome Forums 9 05-04-2023 08:36 AM
Thinking about replacing oven with microwave Stefrobrts Stoves, Ovens & Microwaves 36 01-15-2006 10:02 AM
Installing a microwave in 1976 Overlander? tin can luv Stoves, Ovens & Microwaves 8 01-31-2004 08:09 PM
microwave in a 66 safari? kc airstreamer Stoves, Ovens & Microwaves 4 09-15-2003 08:58 AM
Suggestions on new tow vehicle Diana Langley Tow Vehicles 3 07-08-2003 07:31 AM
