Old 08-29-2010, 03:56 PM   #1
Splitrock's Avatar
Sioux Falls , South Dakota
New gas lines and pressure tester
My maintenance schedule gets me to replacing two damaged gas lines. I air soap tested the existing lines and about every joint was leaking so I decided to replace everything from the original 5/8" feeder back.
Name:	GAS TESTER (Small).jpg
I wanted to test with a gas test gage but I couldn't lay my hands on one on a Sunday, so I picked up a valve stem with 1/8" threads at the auto parts store, a 1/4" brass "T", a reducer, a 60lb gage, and a 1/4" nipple. I attached the gage to the gas line and soap tested the gage set up. Now I'm pressure testing at 25 lbs.
Name:	GAS TESTER REGULATOR (Small).jpg
I loaded the line with shop air reduced to 25 pounds.
Gary
Old 08-29-2010, 06:39 PM   #2
x
XXXX , XXXX
Gary that is way too much pressure. Propane is fed to your appliances from the regulator at one half PSI. I sure hope you have not damaged the aplliance valve from too much pressure.
wasagachris is offline   Reply With Quote
Old 08-29-2010, 07:12 PM   #3
Splitrock's Avatar
I have all the shut offs turned off. I'm testing the lines for leaks.
Loose gas lines Mrwaterway LP Gas, Piping, Tanks & Regulators 17 11-22-2009 04:31 AM
replacing gas lines bennobel Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-08-2009 06:37 PM
LP Gas Lines Silverhobby All Argosy Trailers 6 01-24-2008 09:25 PM
Replacing Gas Lines? Frostyone LP Gas, Piping, Tanks & Regulators 2 05-14-2006 09:21 PM
gas lines scootertrash LP Gas, Piping, Tanks & Regulators 1 02-27-2003 10:00 AM
