Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 03-22-2009, 08:46 PM   #1
bigjohn's Avatar
Profile:  1975 31' Sovereign
Easley , South Carolina
Need help with an old Magic Chef oven
I'm restoring a 1975 31 ft AS Sov. that has a seperate oven mounted in the wall. The oven look's as if it has never been used. I did discover a problem, the temperature control is stuck. I'm afraid to force it in fear I may break off the shaft. Does anyone have any suggestions on how I can get the temp control off and how do I restore the control? I want to preserve the unit if I can. Your help would much appreciated.
John Owens
Member #9091
The difference between genious and stupidity is that genious has it's limits: Einstien
bigjohn is offline   Reply With Quote
Old 03-22-2009, 09:07 PM   #2
C Johnson's Avatar
Profile:  1965 17' Caravel
Portland , Oregon
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Try soaking it in some penetrant and leave it overnight. Try to get it down the shaft and inside the control.
BTW - you do know that you have to push in and then turn right - No offense just checkin.
Chris AIR # 7276 WBCCI # 7276
WBCCI Forum Save Wally Forum
Photos of Project 2k5 My Pictures
C Johnson is offline   Reply With Quote
Magic Chef Oven danesh Stoves, Ovens & Microwaves 34 03-31-2009 03:21 PM
Magic chef Oven Joyce K Glass Stoves, Ovens & Microwaves 4 03-15-2008 12:34 PM
Discolored oven door glass on Magic Chef oven Ahzmyrah Stoves, Ovens & Microwaves 0 09-28-2007 08:45 PM
Oven problem on Magic Chef tincanalley Stoves, Ovens & Microwaves 2 07-18-2006 09:33 AM
Magic Chef Oven Door John Sims Stoves, Ovens & Microwaves 1 10-18-2004 08:06 PM
