Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 11-03-2006, 09:23 AM   #1
Profile:  1979 31' Sovereign
Socorro , New Mexico
Need furnace help- brrrrrr
I hope someone has a simple solution to my problem. We have a 74 Land Yacht with a Surburban furnace and we can't keep the pilot lit. We go through the sequence of turning off the gas and then on again and pushing the button. The pilot lites and then the flame fades away. We removed the furnace and put a new thermocouple in but it still fades away. Is there a technical manual somewhere where one can trouble shoot this or does someone know why it is doing this? We are freezing in MN and are heading south as soon as we can. Also the people at the Camping World in Minneapolis were very helpful with putting in a new fridge. Any help with this furnace would be greatly appreciated, freezin in MN Dancepancha
dancepancha is offline   Reply With Quote
Old 11-03-2006, 09:26 AM   #2
moderator
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
How about a couple of small cube type ceramic heaters? We use one and It keeps our trailer toasty! ( but... you have to be plugged into shore power)
77 Argosy Minuet, 6 metre | 77 Argosy 24, Rear door
AIR # 3181 | WBCCI # 5575
Bullies thrive where leadership fails
Janet is offline   Reply With Quote
Old 11-03-2006, 09:42 AM   #3
Smile
Thanks for the suggestion but we are on the road for a year and like to boondock so we would rather use the system that is there but thanks for the suggestion.
Old 11-03-2006, 09:43 AM   #4
Profile:  , Minnesota
Images: 59
I would use a hair dryer to heat the valve up to room temperature and try it again. Sounds like the valve is sticky. Or maybe clogged with condensate or oil.
Also possible that the new thermocouple is defective.
I believe there is a Suburban service rep in Hopkins, MN, just west of Minneapolis. I don't have his phone # but could find it if you are near there.
Here's a service manual: http://www.bryantrv.com/docs2/docs/suburbantech.pdf
Old 11-03-2006, 11:43 AM   #5
Thanks Mark for the manual. Do you know where I can find a model # on the furnace? I have looked but it is not obvious, I thought there might be a trick. dancepancha
Old 11-03-2006, 11:52 AM   #6
Images: 59
Sorry, I have a different model, I don't know where it is on yours.
A few other things: Are you running low on propane? Might be a propane regulaor problem with this cold weather.
Here is a link to Suburban Q&A: http://www.rvcomfort.com/suburban/se...-Question-2821
And a list of their service reps: http://www.rvcomfort.com/suburban/se...es_repairs.php
Old 11-06-2006, 03:48 AM   #7
Commercial Vendor
Profile:  Currently Looking...
east stroudsburg , Pennsylvania
sounds like the safety valve is bad
RV_cool is offline   Reply With Quote
Old 04-11-2007, 12:25 PM   #8
Profile:  1977 29' Ambassador
Brandon , Mississippi
Spastic Furnace
Hopefully my post will float this thread to the top, thus getting the attention of the Furnace Gods and enlightning me on my problem.
My furnace has an issue on shut down. The fan cycles on and off in a dimenishing pattern when the heating cycle is complete. The way I understand the internal heater logic, the fan runs for 1) a timed cycle AND 2) until the combustion chamber is cool.
Just guessing, mine is only doing #2 (oops hidden meaning). The gas shuts off, the fan cools down the thermal sensor and stops. Then the thermal sensor gets some BTU's transfered to it from the still warm combustion chamber and the cycles starts again.
It seems top work fine if the unit heats for an extended priod. If I flip the switch, wait for the vents to blow heat then flip it off, it will do this every time.
Any Ideas?
-If your gonna start your reply with "I'm not sure, but you could just replace the circuit board", I already got that one, thanks anyway.
Old 04-11-2007, 12:50 PM   #9
Commercial Vendor
Profile:  Corona , California
Any Ideas?
The thermal fan switch is bad.
Andy Rogozinski
Inland RV Center
Corona, CA
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 08:17 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 06:36 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 10:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 10:41 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 09:29 PM
