06-19-2012, 06:59 PM
Alumination
2006 25' Safari
Fort Myers
Microwave stabilizer or screw jack
Greetings
I am not sure what to call it but the need in my AS is to secure the microwave in the opening by the sink. Interestingly AS mentions the need to do so in their manual but did not do it. The microwave slides in to the opening but nothing holds it there. Does anyone have any ideas? I keep thinking about some type of screw-down device like a screw jack or spring tension rod that would have opposing pads that when turned, increase the distance between pads - make sense? If I could get three of something like this I would be able to keep it in the spot. The previous trailer owner bungie corded the microwave in the cupboard.
06-19-2012, 07:23 PM
1974 Argosy 20
Kooskia
, Idaho
I don't know if you have the space but there is a strap system made specifically for this application. It uses very very heavy duty adhesive pads on the shelf and sides of the Microwave, and a strap between them. I found mine at an RV store. I moved my microwave to a new location and no longer use them, but they worked very well to hold mine on a countertop.
They also make some 2" wide Velcro with adhesive backing which might work for you if you ran it to the sides of the Microwave and secured it somehow to the walls of the cabinet, or the floor of it. Just another thought.
06-19-2012, 07:33 PM
Alumination
2006 25' Safari
Fort Myers
Here is the kitchen
Note where the microwave is. The previous owner sawed, yes sawed roughly, the cabinet to fit this larger microwave in the opening but now there is no trim, a rough edge and it moves.
06-21-2012, 07:41 PM
2000 30' Excella
Pittsfield
, Maine
Check with the microwave manufacturer (on line) to see if they offer a mounting flange. It's a simple angle frame that surrounds the microwave. You screw it to the microwave and then slide the whole works into the cutout and screw the frame flanges (i.e. - "finish molding") to the surrounding cabinet. The only caveat is that the rear of the microwave should be supported.
Cracker
06-21-2012, 09:04 PM
St. Cloud
Cracker has it right. Check the mfgr's website for a build-in kit. This should include a face frame and stabilizing straps. Here's a pic of my built-in Sharp from the rear -- showing the back side of the frame and one of the stabilizing straps.
The screws attaching the face frame to the cabinetry are the only anchor point for my microwave ... that's been holding up well. I had to modify the structure to give that a chance to work -- Microwave shelf fails in '06 FB SE.
What's the wall surrounding your microwave? 1/2 particle board? Any chance of a closer picture?
06-22-2012, 08:58 AM
Alumination
2006 25' Safari
Fort Myers
Yes thanks. I spent two days this week on this and some time right after I bought the AS checking on a trim kit- no luck. I greatly appreciate your comments and posts.
Bob, there is only cabinet face there and all jagged, crooked cutout. The original owner used a jigsaw to make it as wide an opening as possible so it is 1" at the top left from the wall and all the way to the cabinet vertical board inside the opening. It is also not squared and the cutting was done at a 45 degree angle from the opening!
I broke down and had a cabinet person conference with me from Micro-trim online for an hour emailing pictures, etc. He told me that the microwave currently in my AS was unsafe. Not that it would catch fire but that it was too big for the opening since it was up against the back all the way, had no space underneath or on the sides and had only 2 inches at the top. He stated that they pull cool air in from the bottom and expel hot air in the back. So, given the size dimensions he suggested a micro that fit would be around 18" wide and 13" deep. I found a few that size and got one. There is no build kit for it either. I contacted several manufacturers and found that the trim kits are built for the larger units only. Whirlpool/Kitchenaid had one for a larger micro and the kits were 24"-30" w for their micro which had similar dimensions to my larger one- 21"w. Dometic has one for their unit and then there is a universal RV trim kit (top and bottom grill only) that is what was in my AS but it was too small for the big one and now that the sides are sawed out, looks ridiculous with the smaller one. I bit the bullet and had a custom one made for the new smaller microwave. They are building a rail system with stops for the feet to keep it from sliding around. It cost me twice what the oven cost but it SHOULD look nice.
This is a problem because it is out of the available general product offerings. It looks as if Airstream got smarter on this one as I noticed on the new ones they have a slide out microwave cabinet - no trim needed and not so size specific.
07-02-2012, 05:11 PM
Alumination
2006 25' Safari
Fort Myers
...and the final result!
After playing with molding and a saw and learning that microwaves pull in cool air from the bottom AND must sit up when enclosed, I was compelled to call micro-trim. This is the result. I installed the custom kit today. It is stainless-look aluminum, fits perfect and came with foot channels and 3m stick L brackets to hold it in place. Although the pic makes it look like the sides are gray, they are the same material as the top and bottom. The channels lift the bottom of the micro by about 2 inches. All I can say is that I am happy. This was one of my ongoing challenges a la Airstream. It is solved and it looks factory! I priced kits from Whirlpool 24" and other sources. I already had the generic top/bottom kit from the RV dealer. That did not help my crooked sides jigsaw cutout issue. This solution also solved the issue of allowing air into the cabinet.
07-02-2012, 06:10 PM
2005 30' Classic
Kingston
Looks great, nice job!!
07-02-2012, 06:31 PM
2006 19' Safari SE
Tucson
Fabulous! Good job!
07-03-2012, 05:44 PM
Alumination
2006 25' Safari
Fort Myers
Thank you 10Smiles and TBRich. I do not mean to sound boastful just happy to have overcome the issue. So many on here have pristine trailers and mine, well has some rough edges, so, when I can improve on a "scar" I am glad to get it taken care of.
| Thread Tools |
| Display Modes |
