Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 09-02-2008, 11:31 PM   #1
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Microwave shelf fails in '06 FB SE
This is a cautionary tale for anybody who chose an option to do without an oven and instead have a convection microwave installed below the stovetop. Unscrew the trim kit from the cabinetry, pull out your microwave and take a look at the horizontal panel that supports all the microwave's weight. I can only thank new axles that this didn't shake apart with a worse outcome!
In my '06 Safari FB SE I was working on the drawer stack right next to the stove/oven last week when I happened to spy a loose plywood panel.
Here is the cabinet layout in the area with drawers removed. The wheel well starts about 8" behind the lowest doors underneath the microwave. The 6 circled screws into the cabinet face frame ended up being the only support for the greatest part of the microwave's 35-40 pounds. Thankfully they held up and did not pull out of the face frame. The red rectangle will be shown in more detail in the next picture.
Name:	A - Front view.jpg
I didn't have to think twice to ask why this plywood panel would be in such a cockeyed position:
Name:	B - Closeup under microwave.jpg
I pulled the microwave. Now I ask -- who the heck would come up with a scheme to support that panel under the microwave on only two sides -- and not the two sides you'd think!
Name:	C - Microwave recess.jpg
The 1" x 1" nailer boards were doing their job with 7 wire staples going into the side panel and 7 going into the bottom horizontal panel.
Name:	D - right support.jpg
Name:	D - right support, staples.jpg
Name:	E - left support, none.jpg
The front nailer board was still doing its job so I left it in place. I removed the side nailer board and temporarily took the dimension lumber microwave supports out so I could get better access. And after a quick trip to Menards for parts (they don't have those in Ohio?) I was able to put everything back together with a couple hours of work.
Name:	F - braces.jpg
First off I used the heavy corner irons to hold the horizontal panel in the proper position. I leveled it and completed the job. "Like a rock" to match my GMC truck!
Name:	G - shelf pulled up with angles.jpg
Name:	H - right repaired.jpg
Name:	I - left repaired.jpg
Old 09-02-2008, 11:35 PM   #2
Images: 13
Fallen arches?
Well.. some tie-in at least. Here's a before & after picture of a natural arch that fell in Utah a few weeks back.
It stood for a few million years. This part of my cabinetry didn't last 2 million minutes. Guess it could have turned out much worse.
Old 09-03-2008, 05:59 AM   #3
craftsman's Avatar
Profile:  2007 25' Classic
Bath , North Carolina
What did they use to cut out these openings, a chainsaw? Someone should invest in some new blades. Nice re-do.
Jack Palmer
craftsman is offline   Reply With Quote
Old 06-30-2009, 08:11 AM   #4
Profile:  2007 25' Safari FB SE
SE , Michigan
DH just inspected our MW/convection oven shelf on our 2007 and it has drop-itis too. I have today off because of the holiday week. We'll be doing the same repair job that Bob did to his AS.
Off to breakfast and the hardware store for supplies.
Teresa
tksbaskets is offline   Reply With Quote
Old 06-30-2009, 09:55 AM   #5
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
These would be great if placed in the QC threads according to their model year so they don't get lost again. I missed this one Bob back last September...nice fix...to bad YOU had to do that. Not great engineering IMHO. There is an Airstream Town Hall thread and I have linked the QC and other threads to it so that Airstream can see these issues in one location (if they chose to read it, which I think they do).
Here is the latest link with links going back to 2004:
2010 Model year quality
Old 06-30-2009, 11:49 AM   #6
LEV ZEPPELIN
crazylev's Avatar
Profile:  2004 19' International CCD
Chicago , Illinois
Chainsaw!!! Hysterical!!! And a dull one at that.
Maybe the factory ran out of some 60 or 80 grit sand paper. Ah, but that takes a minute and a half and time is money...
I have to tell you that my plan someday when I have the AS closer to my workshop/tools is to completely remove every single piece of the interior, save the pieces to use as templates, and re-build everything using nice hardwood, QUALITY materials, fasteners and so on. And add my own embellishments on top of that.
And fix everything that the factory installed to the way I want it. I'm not a carpenter by trade, but can handle my self around a router, table saw, drill press and bandsaw among other things.
AS should think about just selling the basic shell with wiring and plumbing roughed in, and include templates of various configurations for do-it-selfers.
Jonathan
I'm out of my mind right now, but will be returning shortly......
crazylev is offline   Reply With Quote
Old 06-30-2009, 12:09 PM   #7
Profile:  2008 25' Safari FB SE
Crawford , Colorado
Bob, it's good you had your wood stove to cook on while fixing the microwave. I didn't think
Gene
CrawfordGene is offline   Reply With Quote
Old 06-30-2009, 02:51 PM   #8
SE , Michigan
Our convection/microwave shelf is now glued, screwed, and braced. We'll put the microwave back in tomorrow. Our shelf hadn't dropped as far as Bob's had but it was already tipping back and the metal around the opening cracked on both top corners.
Thanks for the thread and helpful pictures!
Teresa
Old 06-30-2009, 03:12 PM   #9
Aluminut
Jonathan
Make sure you replace the axle on that fateful day too as you will without question exceed what the axle is rated to carry.
Old 06-30-2009, 03:23 PM   #10
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
If the 6 screws around the face frame of the Microwave did not pull out I would say the horizontal that dropped was only a jig to support the Microwave while installing and had no function after installation.
In order for the microwave to have caused to drop, rather than road vibration, the bottom and middle screws on the face frame would have had to pull out. The weight of the microwave was supported by the frame only after installation.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
TV Shelf suggestions ellenwall Audio, Video & TV 9 02-05-2007 05:15 PM
Black TV shelf PWRSTRK Audio, Video & TV 4 01-28-2005 01:22 PM
microwave compared to a convection microwave. Happycampers Airstream Motorhome Forums 0 10-21-2003 10:41 PM
TV shelf? Raptorrider2001 1999 Safari 26 03-08-2003 02:49 PM
Overhead Shelf uwe Cabinets, Counter Tops & Furnishings 2 09-01-2002 07:40 AM
