Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 05-10-2007, 08:32 PM   #1
Profile:  2007 22' International CCD
Batesville , Arkansas
Question Microwave Problems
I am new to the Airstream world. My husband and I just purchased a 2007 22' International CCD. During use of the microwave (Tappen) it simply shut off, like it had totally lost power. I checked the breaker and they were all on. After a short while the microwave came back on. . .it acted like it had gotten too hot and had an emergency shut off, then came back on when it cooled down???? Any ideas before I go down the warranty road?
kolakabana is offline   Reply With Quote
Old 05-10-2007, 08:49 PM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
Welcome to the forums. It may be an internal breaker, or a poor electrical connection, internal or in the plug/wiring for the trailer.
It could also be that you didn't have enough voltage coming into the coach, and it shut down because of that. Low voltage at the campground is kind of like breathing through a straw, you could probably do it for a while, but try running while still breathing through the straw, you'll probably pass out. Then regain consciousness later. Try hooking your trailer into known 120 volts, turn on the microwave with a cup of water, and let it run a while. check the voltage while it is running, to make sure it is still getting, oh, 108 volts or so. If it is, and doesn't cut off, your trouble was likely the campground.
(No Longer at Inland RV)
Old 05-10-2007, 10:46 PM   #3
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Airstream Registry
That is likely a thermal cut out on the transformer or magnetron. Like Terry said low voltage can cause things to run hotter than they should. You may also have blocked cooling vents.
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Old 05-11-2007, 06:29 AM   #4
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
I agree. My Microwave at home did this. The internal fan was not operating, I noticed it sounded more quiet than normal. Same symptom. Took it back (after I unmounted it from the wall) and it was replaced since it was new.
I would check with either a dealer and or the factory.
Also please read and post to the QC threads on your unit. Here is a link to the 2008 model year, which also has links to 2004, 2005, 2006 and 2007:
2008 model year quality....
Old 05-11-2007, 07:44 AM   #5
Profile:  2006 30' Classic S/O
Erie , Pennsylvania
Maybe brown power? If your sure it was not the power going to it or lack of, I would push to have the dealer swap it out.
totalstream is offline   Reply With Quote
Old 05-11-2007, 06:10 PM   #6
Thank you all. Your comments have been very helpful and gives us a plan of action.
Generator Problems thenewkid64 General Motorhome Topics 27 05-07-2003 09:36 PM
Computer problems bhsl8 Forum How-To's & Support 4 11-20-2002 07:55 PM
New Microwave Suggestions 1985air345 Stoves, Ovens & Microwaves 3 08-30-2002 08:49 AM
Microwave not working 1985air345 Airstream Motorhome Forums 4 08-28-2002 02:08 PM
Fridge Cooling Problems 68International Refrigerators 6 07-10-2002 03:53 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
