Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 08-29-2007, 08:50 PM   #1
millvalleyca's Avatar
Profile:  2008 27' International CCD FB
Mill Valley , California
Microwave oven and Air conditioner
Hey guys another question from this newbie
When I use my microwave while the air conditioner is on it trips the circuit breaker. Is this common or should I have Toscano look at it when I take the AS in for skin replacement. Is something wrong with the wiring? Should they be on separate breakers? It happens everytime the two are on.
millvalleyca is offline   Reply With Quote
Old 08-29-2007, 09:14 PM   #2
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
We had a 1000 watt microwave and had sinilar problems. We replaced it with a small 600 watt unit; it works a lot better.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 08-29-2007, 09:41 PM   #3
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula maybe Helena soon , Montana
DO you have a electric/gas water heater? I have tripped the 30A breaker (main trailer) when using the micro with the AC on. IF you are tripping the AC or the micro breaker then you may have a problem.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 08-29-2007, 10:22 PM   #4
ROBERTSUNRUS's Avatar
Lakewood , California
Hi, you should be able to use the microwave and air conditioner at the same time. Was it the outside source breaker that kicked or the one in your trailer? A low voltage source could cause this to happen. Or if you have the microwave oven, the air conditioner, and an electric water heater on at the same time; This is too much draw for a 30 amp circuit. Other than that, have each item tested for excessive draw.
2005 Safari 25-B
"Le Petit Chateau Argent "
[ Small Silver Castle ]
Blue Stripes, American flag, Edition
2000 Navigator / Equal-i-zer / P-3
AIR #12144
Old 08-30-2007, 05:54 AM   #5
Cyclist
henw's Avatar
Profile:  2007 28' International CCD
Windermere , Florida
We have the same issue. Microwave and AC = tripped breaker. Even with lights and TV off. Rule is turn off the AC to run the Microwave.
Tom
henw is offline   Reply With Quote
Old 08-30-2007, 07:50 AM   #6
genearnold's Avatar
Profile:  1992 34' Limited
Boise , Idaho
With my Limited, I have no choice. The A/C is wired to a switch that redirects the current to the microwave when needed. Impossible to use both at the same time.
Gene
'92 Limited 34ft; '96 Dodge Cummins 4X2, 5speed
genearnold is offline   Reply With Quote
Old 08-30-2007, 08:20 AM   #7
InspectorDread's Avatar
Profile:  1987 34' Excella
Mobile , Alabama
Same goes for my 87 34' Excella. There is a factory installed switch located in a cabinet above the stove. If I want to use the microwave, I flip the switch. It cuts power to the air conditioner and activates the microwave.
InspectorDread is offline   Reply With Quote
Old 08-30-2007, 10:28 AM   #8
Sounds like a common issue you just live with. It's the inside breaker that goes off.
Thanks guys
Old 08-30-2007, 10:49 AM   #9
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I can run my AC and Microwave/Convection at the same time without consequence. I do have the 15K Penguin AC/heat pump model. However if I have the water heater on electric, that combined load has sometimes caused campsite site breakers to trip.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
jcanavera is online now   Reply With Quote
Old 08-30-2007, 11:44 AM   #10
Condoluminum's Avatar
Profile:  1988 25' Excella
Sunnyvale , California
Airstream used to install switches..
Our Excella 25 had a wall switch hidden over the stove in a cupboard that switched power from the A/C to the factory installed microwave over the fridge... We converted that space to storage cabinet, and use compact microwave tabletop unit, but general rule is that the breaker won't carry both microwave (600 to 800 Watts) plus the A/C at 23 Amps +/- to get compressor going, as well as load from power converter/charger feeding 12V systems...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 09-06-2007, 07:07 PM   #11
bandboss's Avatar
Profile:  2005 31' Classic
Placentia , So. Calif.
The breaker on the power pedestal blew a few times when running AC and micro, but the breaker in the rig never did. Now I use an outlet adapter and plug in to the 50A outlet on the pedestal. Looks like the current draw is close to the 30A, but not enough to blow the 50 or the breakers inside.
Dan
2004 8.1L GMC Yukon XL pulling 2005 Classic 31'
bandboss is offline   Reply With Quote
Pingbacks are On
upgrade to convection microwave on 1997 International CCD28 rnhunter Stoves, Ovens & Microwaves 15 08-14-2007 08:46 PM
Cool air, weak fan? RedSHED Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-31-2007 08:17 AM
rv microwave??? safari05-25 Stoves, Ovens & Microwaves 23 02-09-2007 01:48 AM
G W Bush... canny_banjo_man Off Topic Forum 562 09-14-2005 11:02 AM
Oven won't light jyobp Stoves, Ovens & Microwaves 9 04-19-2004 07:01 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
