Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 01-27-2007, 06:16 PM   #1
ayresdream's Avatar
Profile:  1971 29' Ambassador
Merritt , British Columbia
Microwave/Convection Oven - Vent needed?
We want to put in a microwave/convection oven in the space where the old oven was. Do we need to be concerned about venting the unit because of the heat the convection part will generate?
ayresdream is offline   Reply With Quote
Old 01-27-2007, 06:20 PM   #2
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Most Micro/convections that I've installed require a vent to the exterior wall. IIRC, the only one that doesn't is the VERY expensive Dometic, but that is a micro only. The heat from the convection needs some place to go. You can probably vent it inside the trailer, but it might get a little warm in there when you use it!
Lew Farber -Certified Master RV Tech (currently on Forums sabbatical)
WBCCI #1456/VAC (assoc) #1456 AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 01-27-2007, 06:42 PM   #3
Profile:  2004 30' Classic Slideout
Ft. Myers , Florida
lewster, We have the micro,convection setup in our 04 classic. The oven vents into the cabinet. When we baked some potatoes last summer we got a bunch of white smoke out of the cabinet. I was wondering if the heat was to much for that carpet wall covering they have inside the cabinet.
--Mark and June-- "Every time I feel the urge to exercise, I go lay down until it passes." Mark Twain
Wharf Rats is offline   Reply With Quote
Old 01-27-2007, 06:46 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Good question -- think I'll go out to my '06's OEM micro/convection installation and take a look tomorrow... My impression is that it is not ducted but counts on being under the stove/under the hood.
It's supposed to get all the way up to 9 degrees, so I can do it. (that's blue, not purple)
Old 01-27-2007, 08:37 PM   #5
Commercial Vendor
lewster's Avatar
CM,
Not the first time I have heard of that....I really don't know what they were thinking!!!! You might want to get the carpet and any other heat sensitive materials out of the heat path and replace it with a more heat resistant material. The other option is to cut in a vent (with a blower fan) into the side wall of the coach. I'm sure you could get one from Jackson Center that would match the existing one for the stove vent. It should be a fairly straight-forward install.
Old 01-28-2007, 12:35 AM   #6
2airishuman's Avatar
Profile:
hi ayresdream...
it depends on which model is chosen...
the sharp microwave/convection commonly used in newer a/s (2002-2007) doesn't need venting...
it can be used on a counter top or wall/space mounted wtih a kit that provides an air gap on 5 sides....
this is sharp model r-820bk...
it does need 2 inches of clearance on all sides to allow hot air to circulate.
and it should NOT be mounted near another heat source that will damage it...
that is why most of them aren't mounted over the range top...
under the range top should be fine.
i'm not sure what other mic/conv combo oven models a/s has used...
the sharp is 900 watts and works well in both modes...
wally world used to stock it for 280$ or so...but models do change.
there are many makes/models like the sharp that don't require venting...
usually it is the commercial ones (>1800 watts) that need special venting...
for those of you that have the sharp model, here is a link to the owners manual online...
http://www.sharpusa.com/files/mic_man_R820B.pdf
installation is on page 3 if you're interested...
as for the white smoke...
that could be from the wall fuzz but i'd expect it 2 be associated with the smell...
of plastic burning....
microwaving with paper plates is ok but using them in convection mode will burn paper...
so too, the combo settings that include a 'browning' stage using the convection mode...
i forgot about this once...
and had white smoke too!
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 01-27-2007, 07:00 PM   #7
Ft. Myers , Florida
Bob, Our setup is in a cabinet across from the stove. When the space started smoking I shut everything down and pulled the unit out to check for any hot spots or damage, there was none. When I got home I pulled the unit out and checked it out completely with no problems. It does seem kind of odd that AS would put a fabric in a space that gets hot.
Old 01-28-2007, 01:23 AM   #8
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
That's interesting. I just put a Sharp R820bk in the Ambassador. I chose it because it was the smallest convection I could find with the built-in kit. I did not know they were used in current airstream production.
Anyone who has one, I be interested to see how it was mounted in the cabinet. I ended up adding an L bracket on the back and a bracket under the front as well.
The built in kit has two holes in the front that I also used to mount but they do not seem very substantial.
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 01-28-2007, 09:01 AM   #9
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
I don't believe Airstream vents the convection ovens outside FWIW. I've looked at several units over the years and have yet to see an oven vent on the outside......
Old 01-28-2007, 12:20 PM   #10
Profile:
Originally Posted by Safari Tim
That's interesting. I just put a Sharp R820bk in the Ambassador. I chose it because it was the smallest convection I could find with the built-in kit. I did not know they were used in current airstream production. Anyone who has one, I be interested to see how it was mounted in the cabinet. I ended up adding an L bracket on the back and a bracket under the front as well. The built in kit has two holes in the front that I also used to mount but they do not seem very substantial.
hi tim...
here is a link to some galley shots. the mic/conv is mounted above the 'applicance garage'...
no fooling that's what they call that space...
http://www.airforums.com/forum...4&d=1139375478
in this thread...http://www.airforums.com/forums/207075-post2.html
anyway the face plate has been off mine and the oven removed for unrelated repairs...twice.
a/s uses the sharp kit and no extra strapping that i could see...
basically it plugs into a ac outlet and sits on a shelf, with no extra tiedowns...
the faceplate has held it well for 2 years...
also it's obvious how big the enclosure is made...
adding 2-3 inches on all sides for air circulation makes the oven look much bigger than true size...
still it works well (bakes a wicked pizza & grills chicken/chops or steak nicely)...
to keep the rotating bits from moving,
i store paper towels/plates inside or dry goods like bread or chips while on the road...
cheers
2air'
Old 01-28-2007, 10:15 AM   #11
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
My sharp convection/micro has a venting "collar" vent at the bottom and top of the surround. It vents back into the cabin.
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://Michelles-Adventures.US
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Old 01-28-2007, 04:29 PM   #12
Safari Tim's Avatar
Images: 35
Wow, that's amazing they do not strap it down anymore than the vent kit. The kit is only meant to set it on a shelf enclosure in a house that does not roll down the road .
In the first shot you can see an inverted V brace I made and added. Its behind the lower grill in the center. I put a second L bracket in the rear as well before secureing the cook top.
The second picture shows the vent kit added to microwave so everyone can get an idea what we're talking about.
I'm glad to hear it works well. I have not even powered it up yet. The circuit is not wired in the breaker box yet .
ID:	31463   Click image for larger version
-Tim
Magic chef Oven Joyce K Glass Stoves, Ovens & Microwaves 4 03-15-2008 12:34 PM
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 07:03 PM
Antenna & Oven Difficulties Tamara General Repair Forum 13 07-30-2002 05:33 PM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 04:52 AM
No Buns in this Oven NSMITH Stoves, Ovens & Microwaves 2 06-03-2002 08:54 PM
