Old 05-25-2012, 06:43 PM   #1
Mustang , Oklahoma
Meynell stove/oven questions
I tested the stove/oven today on my vintage kin trailer (1963 Avalair) and the gas valve on the oven doesn't seem to make much difference on the flame height.
Does anyone know how these are supposed to act?
I think the gas valve could be suspect, if so where could I find one?
All of the stove top burners are working correctly. The make is a 1963 Meynell model 75ab.
Root
The Adventures of Avalair
Roothawg is offline   Reply With Quote
Old 05-28-2012, 08:19 AM   #2
Mustang , Oklahoma
Anyone?
Old 05-28-2012, 08:36 AM   #3
1974 Argosy 20
Kooskia , Idaho
I don't know anything about that specific brand, but most RV ovens I have seen in trailers as early as 1960 have a pilot light which is first lit, then it in turn lights a second larger pilot light, which in turn warms a thermocouple, which, when heated enough, allows gas to flow to the main burner. Then the main burner is cycled on and off (not modulated in size or height) by the oven thermostat. Sounds complex but it is all done for safety reasons.
If the second larger pilot goes out, the thermocouple cools and no gas can then go to the main burner, even if the thermostat says "go". When the thermostat is turned all the way to off, the second, larger pilot light goes out but the first, and smallest pilot light remains lighted unless the oven gas valve is closed or the control is turned to "pilot off".
Again, that is the sequence of all Magic Chef and Travler stove ovens I have seen. I don't know if it applies to yours.
Old 05-28-2012, 09:13 PM   #4
Mustang , Oklahoma
Thanks. It may be ok after all. I will do some testing with a thermometer.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
