Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Stoves, Ovens & Microwaves
Old 03-25-2004, 09:07 PM   #1
Joe62984's Avatar
Profile:
Magic Chief Oven Parts
Does anyone know where I can purchase parts for a Magic Chief Oven that was standard to the 1970 Overland: Need a thermostat.
Thanks, Joe
Joe62984 is offline   Reply With Quote
Old 03-25-2004, 09:10 PM   #2
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
You might check with Andy at Inland RV:
www.inlandrv.com
Eric
Old 03-27-2004, 09:48 PM   #3
Joe62984's Avatar
Profile:
MAGIC CHIEF OVEN PARTS
I located the thermostat for a 1970 Overland from Harts Enterprises in Alabama. Phone 800 877 7311, had in stock was to be shipped out the day I ordered it. Joe
Old 03-28-2004, 08:35 AM   #4
gregg's Avatar
Profile:
Thanks-I need exactly that part and I have been putting off the search. Thanks again.
gregg is offline   Reply With Quote
Old 05-21-2004, 09:06 PM   #5
Tom Nugler's Avatar
Profile:  1972 25' Tradewind
McHenry County , Illinois
oven will not work stove top is fine any ideas?
Tom Nugler is offline   Reply With Quote
Old 06-11-2004, 12:16 AM   #6
AYRSTRM2's Avatar
Profile:  1966 22' Safari
Armada , Michigan
Can you be more specific? Is the pilot light lit? Does it stay lit? Etc...
AYRSTRM2 is offline   Reply With Quote
Old 06-12-2004, 07:08 PM   #7
Joe62984's Avatar
Profile:
Oven lighting problem.
I hav e since determined that my problem is the thermo-couple assembly. I am sure this is the wrong name for device, but it will not let gas into burner so it can burn. Joe
Old 06-12-2004, 10:43 PM   #8
overland's Avatar
Profile:  1970 27' Overlander
Mathiston , Mississippi
We have a 70 overlander and tried lighting it when we first got it and didn't seem to get gas. Can anyone tell me where the cut off would be. I told my husband "don't worry about it I don't plan on cooking" but it just might be nice in the future if the bug to cook hits.
overland is offline   Reply With Quote
Old 06-13-2004, 07:16 AM   #9
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
I have two values that need to be open for the stove to work. One is under the top cover. If you pick it up the burner crates fall off and there is a value on the right that controlls burners and oven gas. The other one is under my trailer on the same side. I don't know if this is standard or not but I suspect all have an outside shut off for safety. It takes awhile for the line to clear of air. Don't forget to check all connections for leaks . There may be a reason it's been turned off outside . One of those gas detectors is IMO a must have item.
SOFI Member
Over59 is offline   Reply With Quote
Old 06-13-2004, 09:41 AM   #10
overland's Avatar
The stove top has been working just fine. My oven is on the wall on the other side of my sink. Is there another cut off valve or did we just not wait long enough?
