Old 05-06-2010, 01:25 AM   #15
Originally Posted by Inland RV Center, In View Post
Thanks.
I will check tomorrow and see if that part is still available.
Andy,
Were you able to find the thermostat for the model number Noreen had? I am in the same state with ours needing the thermostat (oven control unit where knob connects along with the copper wire going down into the oven). Our Magic Chef oven model number is the same (BT22JA-4TVX-M3). The oven part number is 690134. I can't clearly read the number on the thermostat. It is very close to Noreen's above but a few digits can't be read.
I have called Marcone (marcone.com) and they sent me an electric oven thermostat (almost twice).
Here is a picture of it but it is opened up:
The back side (left large piece in photo) has 3 threaded holes for the connections. The reason I opened it was the copper temperature wire had broken off at the edge of the unit and I thought I may be able to re-connect inside but was futile...
Old 05-19-2010, 07:42 PM   #16
If anyone is looking for this thermostat, TWTwinkie volunteered his off a unit he took out. He didn't know if the oven worked but for those looking, worth a shot. He also said his igniter tubes are in decent shape. See post link below
http://www.airforums.com/forums/f426...ion-64655.html
Magic Chef Thermostat Brick Stoves, Ovens & Microwaves 20 03-12-2010 08:53 AM
Magic Chef needs magic fix Sheridan Stoves, Ovens & Microwaves 8 11-21-2009 03:44 PM
Oven Thermostat for Magic Chef T-727, '68 Safari 26.982 amu Stoves, Ovens & Microwaves 10 03-31-2009 07:26 AM
Harper-Wyman Oven Thermostat (Magic Chef Range) DesertStream Stoves, Ovens & Microwaves 7 07-17-2007 04:47 AM
Magic Chef Oven Thermostat retrocowgirl Stoves, Ovens & Microwaves 1 09-17-2006 10:55 PM
