Old 06-30-2010, 06:08 AM   #1
1965 22' Safari
Poland , New York
Magic Chef Stove
The Magic Chef stove in the 1965 Safari we're restoring is in excellent working order and we would like to keep it. The problem is water leaked down through the range hood and the top, cover & burner bibs are pitted and rusted. Any ideas on how to salvage this? I got an estimate to have them "rechromed" and it was $1600!!!
JoAnn Smith is offline   Reply With Quote
Old 06-30-2010, 08:17 AM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Yeah right.... I would try a wire brush for a drill to clean it up with. Then find some chrome color paint for a BBQ or engine and spy away. it should hold up.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-30-2010, 08:30 AM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
You could use this - let it dry and heat it in an oven to 400 degrees to set the finish.
StainlessSteelPaint.com
Or, consider having the parts powder coated.
Old 06-30-2010, 09:46 AM   #4
tpi
Trabuco Canyon , California
Are the items completely rusted through in spots? Why not shop around for a plating job? Somebody should be able to do them much cheaper than that.
tpi is offline   Reply With Quote
Old 06-30-2010, 09:46 AM   #5
1976 Argosy 24
Excelsior , Minnesota
I had the same issue. Took mine to a powder coating enterprise. They said they could clean it up and powder coat it to about the same finish for about $100.00. I am waiting for a call to come pick it up. I also took my rusted stabilizer jacks for the same treatment based on what someone else on the forum did.
Hope it works, will let you know when I see it.
Steve Finch is offline   Reply With Quote
Old 06-30-2010, 10:37 AM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
If someone quoted you $1600 then they didn't want to do the work or you happened to call a place that specializes in jewelry-quality restoration.
Find another plating shop. There are lots of them. Also, some of them offer different grades of service, and if you make it clear how what you're trying to accomplish in terms of durability and polish you may get a better price.
Old 06-30-2010, 12:28 PM   #7
Janie Q's Avatar
1972 25' Tradewind
Hammond , Louisiana
We took our burners and the thing under the burners to get power-coated. We waiting until the owner had other work to do and he did ours at the same time. Charged $40.00. We wished we would have done the cover for the stove-top at the same time. It didn't look bad until we had the other stuff done.
Janie Q is offline   Reply With Quote
Old 06-30-2010, 12:36 PM   #8
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Oven
We restored and updated a 65 Safari and had the same problem with the Magic Chef. We took ours out completely and put in a new counter top, sink and burner top. In the space the oven occupied we added more shelves and made two doors to match the rest of the cabinets. We don't like using an oven in a trailer (too much heat). Good luck which ever way you go.....Tim
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 07-01-2010, 04:16 AM   #9
1965 22' Safari
Poland , New York
Magic Chef Stove
Thanks everyone. I have seen some pictures where someone had powder coating put on theirs and it looked great. Think we're going to try that.
Old 07-05-2010, 02:53 PM   #10
2000 34' Limited S/O
Jamestown , North Carolina
Stove question
Our unit has a gas top stove but no oven below, instead we have drawers. On the opposite side of the galley, we have a microwave/convection oven built in which my wife does not like. I am planning to put in a gas oven beneath the gas top and take the micowave/convection oven out. I wondered if there were suggestions on the type of oven to buy for best performance and quality.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Magic Chef stove handle needed... 59er Stoves, Ovens & Microwaves 5 03-02-2011 04:08 PM
Magic Chef 1 - 720 Stove classicshow Stoves, Ovens & Microwaves 1 10-10-2009 03:00 AM
Magic Chef Stove Stone Ridge Stoves, Ovens & Microwaves 8 02-18-2009 07:15 AM
Magic Chef Stove Tin Lizzy Stoves, Ovens & Microwaves 2 06-20-2006 02:20 PM
